Alphacool Apex thermal pad Soft 18W/mk 120x20x1.5mm
  • 13485
  • 4250197134859
  • 0,027 kg
€49.98 *
Content: 24 cm² (€2.08 * / 1 cm²)
€4.28*
€69.98*
WÄM Alphacool Apex thermal pad Soft 18W/mk 100x100x1.5mm
€179.98*
WÄM Alphacool Apex thermal pad Soft 18W/mk 120x20x0.5mm
€21.98*
Alphacool offers a wide range of thermal pads for effective heat dissipation of electric... more
Powerful!
Increased lifespan!
Versatile!
Technical data thermal pad
Dimensions (L x W x H)120 x 20 x 1,5mm
Thermal Conductivity (ASTM D5470)17.8 W/mK (±10%)
Hardness (ASTM D2240)65 (Shore 00) (±5)
Working temperature-50 to ~150°C
Volume Resistance (ASTM D257)6×10¹² Ohm-m
Dielectric Breakdown Voltage (ASTM D149)4 KV/mm (±10%)
Density (ASTM D792)3.5 g/cm³ (±10%)
Elongation (ASTM D412)20%
Flame Rating (UL 94)V-0
Colorlight grey
Thickness: 1,5mm
Surface dimensions: 120 x 20mm
Thermal conductivity: 18W/mk
WAGZ Alphacool Eisschicht Wärmeleitpad - 14W/mK 100x100x1mm PHT EOL
Alphacool Ice Layer Thermal Pad - 14W/mK 100x100x1mm
Content 100 cm² (€0.80 * / 1 cm²)
WAR Alphacool Eisschicht Wärmeleitpad - 14W/mK 120x20x0,5mm - 2 Stück PHT EOL
Alphacool Ice Layer Thermal Pad - 14W/mK 120x20x0.5mm - 2 pieces
Content 48 cm² (€0.62 * / 1 cm²)
€29.98 *
WÄM Alphacool Apex Wärmeleitpad Soft 18W/mk 120x20x1mm
Alphacool Apex thermal pad Soft 18W/mk 120x20x1mm
Content 24 cm² (€1.67 * / 1 cm²)
€39.98 *
WÄM Alphacool Apex Wärmeleitpad Soft 16W/mk 120x20x0,5mm
Alphacool Apex thermal pad Soft 16W/mk 120x20x0.5mm
Content 24 cm² (€0.62 * / 1 cm²)
WÄM Alphacool Apex Wärmeleitpad Soft 18W/mk 120x20x0,5mm
Content 24 cm² (€0.92 * / 1 cm²)
€21.98 *
WÄM Alphacool Apex Wärmeleitpad Soft 18W/mk 100x100x0,5mm
Alphacool Apex thermal pad Soft 18W/mk 100x100x0.5mm
Content 100 cm² (€0.60 * / 1 cm²)
€59.98 *
Alphacool Core thermal pad Soft 9W/mk 40x40x3mm
Content 16 cm² (€0.81 * / 1 cm²)
Alphacool Core thermal pad Soft 9W/mk 40x40x2mm
Content 16 cm² (€0.62 * / 1 cm²)
Alphacool Core thermal pad Soft 9W/mk 100x100x1.5mm
€29.98 *
Alphacool Y-Splitter aRGB 3-Pin to 2x 3-Pin 15cm
€3.47 *
€1.68 *
Alphacool Y-Splitter 4-Pin to 4x 4-Pin PWM 60cm
€5.28 *
Alphacool Eiszapfen angle adapter 90° rotatable G1/4 AG to G1/4 IG - 4pcs Set Deep Black
Content 4 Stück (€6.75 * / 1 Stück)
€26.98 *
Delivery date: in 6 - 7 days
33%
€5.99 * €8.98 *
21%
€33.97 * €42.98 *
Alphacool EPDM Tube 16/10 - Black 3m (9.84ft) Retailbox
Alphacool hose AlphaTube HF 16/10 (3/8"ID) - Ultra Clear 3m (9.8ft) retail box 300cm
€39.98 *
