Alphacool Apex Thermal Pad Soft 16W/mk 120x20x0,5mm
  • 13488
  • 4250197134880
  • 0,018 kg
Content: 24 cm² (€0.62 * / 1 cm²)
€4.28*
€69.98*
13489 Alphacool Apex Thermal Pad Soft 16W/mk 120x20x1mm
€34.97*
13491 Alphacool Apex Thermal Pad Soft 16W/mk 100x100x0,5mm
€39.98*
Alphacool offers a wide range of thermal pads for effective heat dissipation of electric... more
Powerful!
Increased lifespan!
Versatile!
Technical data thermal pad
Dimensions (L x W x H)120 x 20 x 0,5mm
Thermal Conductivity (ASTM D5470)16.6 W/mK (±10%)
Hardness (ASTM D2240)65 (Shore 00) (±5)
Working temperature-50 to ~150°C
Volume Resistance (ASTM D257)5×10¹² Ohm-m
Dielectric Breakdown Voltage (ASTM D149)5 KV/mm (±10%)
Density (ASTM D792)3.6 g/cm³ (±10%)
Elongation (ASTM D412)20%
Flame Rating (UL 94)V-0
Colordark grey
€0.98 *
WÄM Alphacool Wärmeleitpad für NexXxoS GPX 3W/mk 30x30x3mm yellow marked PE Bag (4 Stück)
Alphacool thermal pad for NexXxoS GPX 3W/mk 30x30x3mm yellow marked PE Bag (4 pieces)
Content 36 cm² (€0.11 * / 1 cm²)
€3.78 *
63%
€1.58 * €4.28 *
WÄM Alphacool Apex Wärmeleitpad Soft 16W/mk 120x20x1mm
Content 24 cm² (€1.46 * / 1 cm²)
€34.97 *
WÄM Alphacool Apex Wärmeleitpad Soft 16W/mk 120x20x1,5mm
Alphacool Apex Thermal Pad Soft 16W/mk 120x20x1,5mm
Content 24 cm² (€1.87 * / 1 cm²)
€44.98 *
WÄM Alphacool Apex Wärmeleitpad Soft 18W/mk 120x20x1mm
Alphacool Apex Thermal Pad Soft 18W/mk 120x20x1mm
Content 24 cm² (€1.67 * / 1 cm²)
€39.98 *
Alphacool Apex Thermal Pad Soft 18W/mk 120x20x1,5mm
Content 24 cm² (€2.08 * / 1 cm²)
€49.98 *
22%
€46.98 * €59.98 *
€34.98 *
€29.98 *
€4.97 *
6%
€16.98 * €17.98 *
Alphacool Aurora LED Flexible Light - Digital RGB 20cm
Content 20 Zentimeter (€69.90 * / 100 Zentimeter)
56%
Alphacool AlphaCord Sleeve 4mm - 3.3m (10ft) - White (Paracord 550 Type 3) 330cm
€1.98 * €4.47 *
56%
Alphacool AlphaCord Sleeve 4mm - 3.3m (10ft) - Electric Blue (Paracord 550 Type 3) 330cm
€1.98 * €4.47 *
Alphacool Eisbaer screw kit M3 x 5/M3 x 30mm
Content 18 Stück (€0.33 * / 1 Stück)
€5.98 *
22%
WAH Alphacool HDX - M.2 SSD M01 - 80mm - Schwarz EOL
Alphacool HDX - M.2 SSD M01 - 80mm - Black
€6.99 * €8.98 *
Alphacool GPU RAM Aluminum Heatsinks 15x15mm - black 10 pieces.
Content 10 Stück (€0.70 * / 1 Stück)
