Alphacool NexXxoS HPE-45 Full Copper 120mm Radiator
  • 14472
  • 4250197144728
  • 0,748 kg
  • 10
€92.98 *
€62.98*
13000 Alphacool Eisbaer Pro Aurora (Solo) - Digital RGB
€89.98*
€14.98*
15394 Alphacool Core 200 Aurora reservoir D5/VPP Acetal/Acryl
€56.98*
14466 Alphacool Filling bottle Core 500ml
€5.99*
For more than a decade, Alphacool has dominated the market with the NexXxoS Full Copper radiator... more
Connection options & mounting
Safety first
Patented screw plugs
Technical data radiator
L x W x H151.5 x 124 x 45 mm (±3 %)
Quantity of cooling channels28
Material threadsbrass
Threads4x G 1/4 IN/OUT & 1x Fill-/Drainport G 1/4 (max. 5 mm thread length)
Possible fan size120 mm
Possible fan assembly1x one-sided / 2x both-sided
Thread size fan mountingM3
Pressure tested0.8 bar
Fin density16 FPI
Weight595 g
Warranty: 10 years
€1.48 *
Alphacool Eiswasser Crystal Yellow premixed coolant 1000ml
