Alphacool NexXxoS HPE-30 Full Copper 120mm Radiator
  • 14468
  • 4250197144681
  • 0,544 kg
  • 10
€81.98 *
€19.98*
€18.98*
13000 Alphacool Eisbaer Pro Aurora (Solo) - Digital RGB
€89.98*
€12.98*
13063 Alphacool Eisblock Aurora GPX-N Acryl Active Backplate 3090 TI Founders Edition
€29.98*
For more than a decade, Alphacool has dominated the market with the NexXxoS Full Copper radiator... more
Connection options & mounting
Safety first
Patented screw plugs
Technical data radiator
L x W x H151.5 x 124 x 30 mm (±3 %)
Material threadsbrass
Threads4x G 1/4 IN/OUT & 1x Fill-/Drainport G 1/4 (max. 5 mm thread length)
Possible fan size120 mm
Possible fan assembly1x one-sided / 2x both-sided
Thread size fan mountingM3
Pressure tested0.8 bar
Fin density18 FPI
Weight420 g
Warranty: 10 years
Alphacool NexXxos Radiator Fan Mounting Screw M3 x 37 mm - 4 pieces
€3.98 *
Alphacool NexXxos fan mounting screw M3 x 30 mm - 4 pieces
€4.48 *
