Eheim compactON pump 300 230 volts
- Article no.: 1020220
- EAN: 4011708001547
- Weight: 0,219 kg
- Available: Currently there are 2 available - More is on the way
The EHEIM compactON aquarium pump is, true to its name, characterized by its compact design and can be used in a variety of ways thanks to the included accessory bag - the EHEIM compactON 2100-5000 pumps can also be converted for use outside of the water. Thanks to high-quality materials, it can also be used in sea water without any problems.
For even more flexibility, the flow rate can be adjusted on all models, except for the EHEIM compactON 5000.
Advantages of the EHEIM compactON
- Successor to the compact and compact+ series
- Fastening using robust suction cups
- Including accessories such as suction baskets and threaded connectors
- Quiet running due to ceramic bearings (EHEIM compactON 2100 and EHEIM compactON 3000)
- High pumping performance with low power consumption
- compactON 5000 as electronic version for even more efficiency
- Pump capacity per hour at 50 Hz of: 170 l
- Pump capacity per hour at 50 Hz up to: 300 l
- Discharge head at 50 Hz approx. (H max): 0.60 m
- Power consumption at 50 Hz: from 7.00 watts
- Dimensions (WxHxD): 38 x 72 x 62mm
- Hose Ø pressure side: 12mm
- Voltage 230 volts
- Frequency 50 Hz
- Power plug EUR
- Freshwater yes
- Sea water yes
Multilingual assembly instructions (DE_FR_EN)
Multilingual assembly instructions (ES_IT_PT_NL)
Delivery date: in 2 - 3 weeks
