Alphacool Eisblock Aurora RTX 4080 Founders Edition with Backplate
  • 13497
  • 4250197134972
  • 1,599 kg
€49.98 * €159.98 * (68.76% Saved)
€62.98*
€18.98*
ANZ Alphacool Eiszapfen screw plug V.2 G1/4 - Deep Black
€3.48*
€37.98*
€18.98*
€6.49*
The next generation - The Alphacool Eisblock Aurora water cooler for Geforce RTX 4XXX graphics... more
The next generation - The Alphacool Eisblock Aurora water cooler for Geforce RTX 4XXX graphics cards. In order to dissipate the enormous heat of this graphics card generation in the best possible way, numerous optimizations have been made to the water cooler compared to the previous model. The fin structure was adapted and enables a very good water flow while increasing the cooling surface. The modified jet plate with improved inflow engine ensures an optimal distribution of the water on the cooling fins.
Technical Highlights
Chrome-plated copper
Design
Thermal paste & thermal pads
- Nvidia GeForce RTX 4080 Founders Edition, 16GB GDDR6X (900-1G136-2560-000)
- Nvidia GeForce RTX 4080 Super Founders Edition
Technical data cooler
L x W x H218,35 x 176,24 x 42,83mm
Material cooler topacrylic
Max working temperature60°C
Pressure tested0,8 bar
Threads4 x G1/4"
Thickness cooling fins0,4mm
Distance cooling fins0,4mm
Illuminationdigital aRGB LEDs
Power digital aRGB LEDs5V
Number of digital aRGB LEDs12
Technical data backplate
L x W x H205,42 x 122,89 x 6mm
Materialaluminium
52%
Hint!
€4.80 * €9.98 *
€6.49 * €8.98 *
€25.98 *
