Alphacool Core Geforce RTX 5080 Suprim + Vanguard with backplate
  • 10265
  • 4250197102650
  • 1,591 kg
€219.98 *
€19.98*
€37.98*
€35.98*
€125.98*
- MSI GeForce RTX™ 5070 Ti 16G Vanguard SOC
- MSI GeForce RTX™ 5080 16G SUPRIM LIQUID SOC
- MSI GeForce RTX™ 5080 16G SUPRIM SOC (MS-V531 VER:2.0)
- MSI GeForce RTX™ 5080 16G Vanguard SOC (MS-V531 VER:2.0)
- MSI MSI GeForce RTX™ 5080 16G EXPERT OC (G5080-16EC)
Technical data cooler
Dimensions total (L x W x H)181,50 x 161,03 x 34,19mm
Material cooler topAcrylic
Material terminalNylon
Max working temperature60°C
Pressure tested0,8 bar
Threads4 x G1/4"
Thickness cooler bottom3,25mm
Thickness cooling fins0,4mm
Distance cooling fins0,4mm
Illuminationdigital aRGB LEDs
Power digital aRGB LEDs5V
Number of digital aRGB LEDs8
Colortransparent
Technical data backplate
Dimensions (L x W x H)181,50 x 132,50 x 6mm
MaterialAluminium
€34.98 *
