Alphacool ES RTX 5090 Reference 1-Slot-Design with Backplate
  • 10262
  • 4250197102629
  • 1,159 kg
€299.98 *
€19.98*
€37.98*
€35.98*
€125.98*
Alphacool expands its Enterprise series with the latest 1-slot water coolers for the current... more
Alphacool expands its Enterprise series with the latest 1-slot water coolers for the current Nvidia GeForce RTX generation. These solutions are specifically designed for use in server enclosures and workstations, enabling efficient cooling even in densely packed systems.
By employing a thin yet extremely robust carbon plate, these coolers have been designed as 1-slot units without compromising the integrity of the copper block. Paired with rear-placed brass connectors, multiple coolers can be easily stacked on top of each other or side by side within a server case. This thoughtful design saves space, simplifies tubing, and allows for seamless integration into the water circuit.
All water-bearing parts are made from high-quality copper, which offers nearly twice the thermal conductivity of aluminum. Additionally, the copper is chrome-plated rather than nickel-plated, providing extra protection for the cooler. Chrome plating is more resistant to acids, scratches, and other damage, effectively preventing the chipping of coatings.
The GPU water cooler has undergone a complete technical overhaul. To optimize cooling performance, the spacing between the cooler and the components on the PCB was redefined and tested. The water flow was simulated using state-of-the-art software and validated through practical trials. These extensive tests led to improvements in the cooler base and nozzle, ensuring the best possible cooling performance for the new Nvidia GeForce RTX generation.
- Inno3D GeForce RTX™ 5090 iChill X3 (C50903-32D7X-175967H)
- Inno3D GeForce RTX™ 5090 X3 (N50903-32D7-17593928)
- Inno3D GeForce RTX™ 5090 X3 OC (N50903-32D7X-17593928)
Technical data cooler
Dimensions total (L x W x H)224,29 x 119,32 x 21,34mm
Material cooler topCarbon
Material terminalBrass
Max working temperature60°C
Pressure tested4 bar
Threads2 x G1/4"
Thickness cooler bottom3,25mm
Thickness cooling fins0,4mm
Distance cooling fins0,4mm
Technical data backplate
Dimensions (L x W x H)224,29 x 119,32 x 3mm
Thick backplate without spacers1mm
MaterialCarbon
Delivery date: in 7 - 8 weeks
WAC Alphacool ES 1 1U
Alphacool ES 1 1U
€132.98 *
€5.99 *
€27.98 *
