Alphacool Eisbaer (Solo) - 2600rpm - chrome
  • 12938
  • 4250197129381
  • 0,57 kg
€69.98 *
WAGZ Alphacool Eisbaer Quick-Connect Extension Kit
€22.98*
€37.98*
€47.98*
Finally here! The solo version of the Alphacool Eisbaer in Chrome. Make your water cooling a... more
Finally here! The solo version of the Alphacool Eisbaer in Chrome. Make your water cooling a visual highlight! This special variant in Chrome makes your system look very noble and uniform, especially with chrome fittings and tubing.
Your System - Your Possibilities.
Decide for yourself how to build up your loop. Thanks to the G1/4'' connections, you can use all the standard water cooling fittings. This means you can choose the hose thicknesses, colors and fluids that match your system and make it as individual as you are!
Your Pump - Powerful, Quiet, Efficient
Alphacool has installed the proven Alphacool DC-LT 2 Ceramic Pump in the Eisbaer Solo. The pump is well known for running extremely quietly. Due to the insulated pump housing you will hardly hear it and the vibrations are almost completely absorbed. You can also control it from the mainboard.
Intel: LGA 1150 / LGA 1151 / LGA 1156 / LGA 1200 / LGA 1700 / LGA 1851 / LGA 2011 / LGA 2011-3 / LGA 2066 / LGA 755
Technical data pump housing
L x W x H63 x 63 x 68mm
Threads2x G1/4”
Technical data pump
Speed2600 RPM
Voltage6-13,5V DC
Power consumption3,2 W
Maximum flow rate72 L/h
Maximum head1 m
Other technical data
Max working temperature60 °C
Pressure tested0,8 Bar
Base: AMD AM3/AM3(+);AMD AM4;AMD AM5;Intel 115x;Intel 2011(-3);Intel 2066;Intel LGA 1700;Intel LGA 1851;
Dimensions (L x W x H: 63 x 63 x 68mm
Connection: 2x G1/4"
Material base plate: Copper
Material Lid: Carbon fiber;
Alphacool Apex thermal pad Soft 18W/mk 120x20x1.5mm
Content 24 cm² (€2.08 * / 1 cm²)
€49.98 *
Alphacool Core thermal pad Soft 9W/mk 100x100x1.5mm
€29.98 *
€1.68 *
AGB Alphacool Core Distro Plate 240 Links VPP/D5 PHT EOL
Alphacool Core Distro Plate 240 Left VPP/D5
€159.98 *
€33.98 *
WAC Alphacool Core XP³ Brass PHT EOL
€34.97 *
WAC Alphacool Core XP³ Acetal
€29.98 *
L12 Alphacool Core 120mm Lüfter PWM 3000rpm (120x120x25mm)
Alphacool Core 120mm fan PWM 3000rpm (120x120x25mm)
€8.48 *
WZS Alphacool Spritzflasche Core 250ml
Alphacool spray bottle Core 250ml
€4.48 *
20%
€3.97 * €4.97 *
Alphacool EPDM Tube 16/10 - Black 3m (9.84ft) Retailbox
13%
Content 6 Stück (€5.00 * / 1 Stück)
€29.98 *
