Phobya Verlängerung 3Pin - UV Blau 30cm
  • LK
  • 4049469077891
  • 0,007 kg
€0.65 *
Content: 30 Zentimeter (€2.17 * / 100 Zentimeter)
Extension cable for 3-Pin cables e.g. for fans. With rpm signal lead.   Sleeving:... more
Sleeving:
The idea behind these cables:
Technical specifications:
Connectors: 3-Pin extension
UV-reactive blue sleeve, black connectors and black heatshrink
Length: 30cm
Extent of delivery:
1x Phobya extension cable 3-Pin 30cm - UV blue
This product has been reviewed for you:
Aquainfos
Tech-Review
Hardwaremax
Hersteller: Phobya
2. Seite: 1x 3Pin
1. Seite: 1x 3Pin
Bauform: Verlängerung
Sleeving: blau
Hint!
LK Phobya Verlängerung 3Pin - Schwarz 30cm EOL
Content 30 Zentimeter (€10.60 * / 100 Zentimeter)
€3.18 *
€5.68 *
Hint!
LK Phobya Y-Kabel 3Pin Molex auf 9x 3Pin Molex -  Schwarz 60cm EOL
LK Phobya Adapter 3Pin (12V) auf 3Pin (7V) - Schwarz 20cm
Content 20 Zentimeter (€17.40 * / 100 Zentimeter)
€3.48 *
Hint!
LK Phobya Y-Kabel 4Pin PWM auf 3x 4Pin PWM - Schwarz 60cm EOL
€5.28 *
LK Phobya Y-Kabel 4Pin PWM auf 3x 4Pin PWM - Schwarz 30cm
€4.48 *
KAB Alphacool Eis-Matrix Verbindungskabel auf 4pol RGB - 10cm
Alphacool Eis-Matrix connection cable to 4pol RGB - 10cm
Content 10 Zentimeter (€9.80 * / 100 Zentimeter)
€0.98 * €1.98 *
Hint!
LK Phobya Y-Kabel 4Pin PWM auf 6x 4Pin PWM - Schwarz 60cm EOL
Content 60 Zentimeter (€12.47 * / 100 Zentimeter)
€7.48 *
WZS Spritzflasche 500ml PE-LD
€4.19 *
Hint!
L12 Yate Loon D12SH-12 mit Stecker (2200rpm) ( 120x120x25mm ) EOL
Yate Loon D12SH-12 with plug (2200rpm) ( 120x120x25mm )
€2.49 *
Hint!
LK adapter 4Pin (12V) to 3Pin (7V)
€1.19 * €2.09 *
Alphacool Core Thermal Pad Soft 6.2W/mk 40x40x0,5mm
Content 16 cm² (€0.25 * / 1 cm²)
€3.97 *
WAR Alphacool ES Passive Aluminium Cooler 200x120x25mm
WAR Alphacool ES Passive Aluminium Cooler 100x120x22mm
€25.98 *
L12 Alphacool Core 120mm Lüfter PWM 3000rpm (120x120x25mm)
Alphacool Core 120mm fan PWM 3000rpm (120x120x25mm)
€8.48 *
SZ Alphacool Apex Heat Gun mit LCD 2000W 80-650°C
Apex Heat Gun with LCD 2000W 80-650°C
€39.98 *
Hint!
L92 Yate Loon D90BH-12 mit Stecker (2600rpm) ( 92x92x25mm ) EOL
€3.26 *
ANK Alphacool HF Schnellverschlusskupplungsset G1/4 AG/AG
Alphacool HF quick release connector kit G1/4 OT/OT
€11.98 *
S13 Alphacool Schlauch AlphaTube HF 13/10 (3/8"ID) - UV Weiß 1m (3ft) Retailbox
Alphacool tubing AlphaTube HF 13/10 (3/8"ID) - UV white 1m (3ft) Retailbox
Content 3 Stück (€8.66 * / 1 Stück)
€25.98 * €39.25 *
LED Alphacool Aurora LED RGBW Verbinder 90° - Black EOL
Alphacool Aurora LED RGBW connector 90° - Black
€1.69 * €2.89 *
Alphacool GPU RAM Copper Heatsinks 14x14mm - 10pcs
Alphacool GPU RAM Copper Heatsinks 10x10mm - 10pcs
Content 10 Stück (€1.30 * / 1 Stück)
S13 Alphacool Schlauch AlphaTube HF 13/10 (3/8"ID) - UV Schwarz 1m (3,3ft) Retailbox 100cm
Alphacool tubing AlphaTube HF 13/10 (3/8"ID) - UV black 1m (3,3ft) Retailbox
MKA Alphacool AlphaCord Sleeve 4mm - 3,3m (10ft) - White (Paracord 550 Typ 3) 330cm
€1.98 * €4.47 *
MKA Alphacool AlphaCord Sleeve 4mm - 3,3m (10ft) - Silver Grey (Paracord 550 Typ 3) 330cm
€1.98 * €4.47 *
WACZ Alphacool Eisblock XPX CPU Ersatz Cover - Rot EOL
Alphacool Eisblock XPX CPU replacement cover - red
€5.09 * €9.79 *
WACZ Alphacool Eisblock XPX CPU Modding Kit - Blau EOL
Alphacool Eisblock XPX CPU modding kit - blue
€8.29 * €14.79 *
AGZ Alphacool Aurora LED Ring 60mm - RGB
€11.98 * €14.98 *
WACZ Alphacool Eisbaer/XPX Halterung für Ryzen S. AM4
Alphacool NexXxos fan mounting screw M3 x 30 mm - 4 pcs
€3.98 *
ANF Alphacool HF Verlängerung G1/4 auf G1/4 20mm - Deep Black
Alphacool HF extension G1/4 to G1/4 20mm - Deep Black
€2.78 *
WAN Alphacool HF 14 Smart Motion Mini Cooler - Schwarz
Alphacool HF 14 Smart Motion Mini cooler - black
€2.98 * €5.99 *
Hint!
ZK Phobya ATX/VGA Power Connector Pin Stecker - 20 Stück EOL
Content 20 Stück (€0.05 * / 1 Stück)
€0.90 *
Alphacool double-sided adhesive pad 30x30x0,5mm
Content 9 cm² (€0.18 * / 1 cm²)
€1.58 *
Alphacool Reservoir Clip-On 50mm - black 2 pieces
Content 2 Stück (€1.99 * / 1 Stück)
€3.97 * €7.98 *
LK Phobya Y-Kabel 4Pin auf 2x 4Pin Einzel Sleeving - Schwarz 20cm
Content 20 Zentimeter (€22.40 * / 100 Zentimeter)
€4.48 *
