Phobya Adapter 3Pin (12V) auf 3Pin (7V) 20cm
- Article no.: LK
- EAN: 4049469099848
- Weight: 0,005 kg
Adaptor for connection of a fan with 3-Pin Molex plug (CPU fan, case fan etc.) to a fan socket on e.g. the Mainboard. This adaptor allows operation of the fan with a voltage of 7V instead of 12V which allows a reduction in noise. The great advantage of this adaptor is the fact that rpm monitoring is still possible. Please consider that the speed of the connected fan will be reduced, hence resulting in a lessened airflow.
Technical specifications:
Length: 20cm
Feature: Reduces voltage to 7V
Connection type: 3-Pin standard
Extent of delivery:
1x Phobya adaptor 3Pin (12V) to 3Pin (7V) 20cm
Sleeving: | ohne |
Hersteller: | Phobya |
2. Seite: | 1x 3Pin |
Bauform: | Adapter |
1. Seite: | 1x 3Pin |
