Phobya Y-Kabel 4Pin PWM auf 6x 4Pin PWM - Schwarz 60cm
LK Phobya Y-Kabel 4Pin PWM auf 6x 4Pin PWM - Schwarz 60cm EOL
  • LK
  • 4049469193379
  • 0,04 kg
€7.48 *
Content: 60 Zentimeter (€12.47 * / 100 Zentimeter)
A Y-cable to connect 6x4-Pin PWM fans to one 4-Pin PWM connector. As fan control via the... more
As fan control via the Mainboard with a PWM fan is much more affordable than a fan controller, this cable is perfect to give more flexibility.
The extension cable is sleeved with a black mesh which additionally protects the cable and looks great! This further expands the lifespan of the cable. The ends towards the connectors are fixated with heatshrink for a clean finish.
A white marking on one of the split cables shows from which cable the rpm signal is transmitted.
Sleeving:
The idea behind these cables:
Technical specifications:
Connectors:
1x 4-Pin PWM male
6x 4-Pin PWM female
Colour: Black sleeve, black connectors, black heatshrink
Dimensions: Overall 60cm
Conforms with RoHS
Extent of delivery:
1x Phobya Y-cable 4-Pin PWM to 6x4-Pin PWM 60cm - black
Sleeving: schwarz
Hersteller: Phobya
Bauform: Y-Kabel
1. Seite: 1x 4Pin PWM
2. Seite: 6x 4Pin PWM
LK adapter 4Pin (12V) to 3Pin (7V)
€1.19 * €2.09 *
€1.19 *
Content 30 Zentimeter (€2.17 * / 100 Zentimeter)
€0.65 *
€5.68 *
LK Phobya Y-Kabel 4Pin PWM auf 3x 4Pin PWM - Schwarz 60cm EOL
€5.28 *
LK Phobya 4Pin PWM Verlängerung - Schwarz 90cm
Content 90 Zentimeter (€6.20 * / 100 Zentimeter)
€5.58 *
KAB Phobya 24Pin Netzteil Verlängerung Einzel Sleeving - Schwarz 30cm EOL
€2.58 *
LK Phobya Adapter 4Pin Molex (12V) auf 4Pin PWM - Schwarz 30cm
Content 30 Zentimeter (€13.27 * / 100 Zentimeter)
€3.98 *
€3.98 *
LZ Lüftergitter für Axiallüfter für 120mm schwarz
Fan grill for axial fans for 120mm black
€1.99 *
KAB Alphacool PWM auf Mainboard PWM 40cm schwarz
Alphacool PWM to Mainboard PWM 40cm black
€4.48 *
Alphacool fan cable 4-pin to 4-pin extension 15cm
Content 15 Zentimeter (€33.20 * / 100 Zentimeter)
€4.98 *
WAK Alphacool MCX 2x Verteiler mit 1m 5/3mm Schlauch
Alphacool MCX 2x distributor with 1m 5/3mm hose
Content 1 Gramm (€7,980.00 * / 1000 Gramm)
€65.99 * €89.23 *
WAK Alphacool Eisblock Aurora Acryl GPX-N RTX 3070 Gaming X Trio mit Backplate EOL
Alphacool Eisblock Aurora Acryl GPX-N RTX 3070 Gaming X Trio with Backplate
€73.81 * €149.98 *
Content 5 Gramm (€1,396.00 * / 1000 Gramm)
Alphacool Universal feet for radiators
€24.98 *
€21.98 *
Alphacool HardTube 13mm OD 90° brass 10/30cm chrome
RAD Alphacool NexXxoS XT45 Full Copper 1260mm SuperNova Radiator
€199.98 *
€25.98 * €39.25 *
LED Alphacool Aurora LED RGBW Verbinder 90° - Black EOL
Alphacool Aurora LED RGBW connector 90° - Black
€1.69 * €2.89 *
KAB Alphacool Y-Kabel RGBW 5pol auf 3x 5pol inkl. Stecker - Schwarz 60cm EOL
Alphacool y-cable RGBW 5pol to 3x 5pol 60cm incl. connector - black
Content 60 Zentimeter (€1.98 * / 100 Zentimeter)
€1.19 * €6.89 *
Alphacool y-cable RGBW 5pol to 3x 5pol 30cm incl. connector - black
Content 30 Zentimeter (€3.97 * / 100 Zentimeter)
€1.19 * €5.89 *
LED Alphacool Aurora Flexlight - RGBW 30cm EOL
Alphacool Aurora Flexlight 30cm - RGBW
Content 30 Zentimeter (€13.97 * / 100 Zentimeter)
€4.19 * €9.79 *
Alphacool RGB 4pol LED adapter cable for Mainboards 100cm - black
€1.19 * €4.89 *
WAG Alphacool NexXxos GPX Pro Solo mit Backplate - Schwarz
Alphacool NexXxos GPX Pro Solo with backplate - black
€61.79 *
WACZ Alphacool Eisblock XPX CPU Ersatz Cover - Rot EOL
Alphacool Eisblock XPX CPU replacement cover - red
€5.09 * €9.79 *
WACZ Alphacool Eisblock XPX CPU Modding Kit - Blau EOL
Alphacool Eisblock XPX CPU modding kit - blue
€8.29 * €14.79 *
KOI Alphacool Eissturm Hurricane Copper 45 2x140mm - Komplettset EOL
€215.39 * €249.98 *
PUM Alphacool Laing DDC310 - Complete Edition Eisdecke - schwarz/Acetal
Alphacool Laing DDC310 - Complete Edition Eisdecke - black/acetal
€79.98 * €107.08 *
PUM Alphacool VPP655 PWM - G1/4 IG inkl. Eisdecke D5 - Acetal V.3
Alphacool VPP655 PWM - G1/4 inner thread including Eisdecke D5 - Acetal V.3
€99.98 * €142.78 *
LK Phobya 4Pin PWM Stecker auf Stecker - Schwarz 30cm
Content 30 Zentimeter (€11.60 * / 100 Zentimeter)
€3.48 *
