Phobya 4Pin PWM Verlängerung 60cm
- Article no.: LK
- EAN: 4049469100087
- Weight: 0,01 kg
Extension cable for a PWM device (4-Pin).
As controlling and switching of a PWM fan via the Mainboard is much more affordable than using a fan controller, this cable is perfect for any system with PWM fans!
The cable is shipped without sleeving, hence giving the user maximum freedom in design.
Technical specifications:
Length: 60cm
Connector type: 4 Pin PWM
Extent of delivery:
1x Phobya 4Pin PWM extension 60cm
Please note the difference between a 4-Pin power connector (Molex) and a 4-Pin fan connector (PWM).
Hersteller: | Phobya |
Sleeving: | ohne |
1. Seite: | 1x 4Pin PWM |
2. Seite: | 1x 4Pin PWM |
Bauform: | Verlängerung |
