Phobya Adapter 3Pin (Buchse) auf 4Pin PWM (Stecker) - Schwarz 30cm
- Article no.: LK
- EAN: 4049469124380
- Weight: 0,008 kg
This is an adaptor which has a 3-Pin fan connector and a 4-Pin PWM fan connector.
It can be used to connect a PWM fan to a fan controller or Mainboard. This signal does not pass on a rpm signal, but most fan controllers can adjust the speed of the fan via the voltage.
Sleeving:
The idea behind these cables:
Technical specifications:
Length: 30cm
Colour: Black
Connection type: 3-Pin
Extent of delivery:
1x Phobya adaptor 3-Pin (plug) to 4-Pin PWM (socket) 30cm - black
Bauform: | Adapter |
Sleeving: | schwarz |
1. Seite: | 1x 3Pin |
Hersteller: | Phobya |
2. Seite: | 1x 4Pin |
Liefertermin: in 5 - 6 Tagen
Liefertermin: in 7 - 8 Wochen
