Phobya Adapter 4Pin Molex (12V) auf 4Pin PWM - Schwarz 30cm
  • LK
  • 4049469124359
  • 0,013 kg
€3.98 *
Content: 30 Zentimeter (€13.27 * / 100 Zentimeter)
This cable is intended for connection of a 4-Pin PWM device (CPU cooler, case fan...) to a PSU... more
This cable is intended for connection of a 4-Pin PWM device (CPU cooler, case fan...) to a PSU power connector (4-Pin Molex)
Sleeving:
The idea behind these cables:
Technical specifications:
Dimensions; Molex to Molex 7cm, Molex to 4-Pin PWM 30cm
Colour: Black sleeve, black connectors, black heatshrink
Connectors: 4-Pin to 4-Pin Molex and 4-Pin PWM fan connector
Conforms with RoHS
Extent of delivery:
1x Phobya adaptor 4-Pin Molex (12V) to 4-Pin PWM 30cm - black
2. Seite: 1x 3Pin Molex
Bauform: Adapter
Sleeving: schwarz
Hersteller: Phobya
1. Seite: 1x 4Pin Molex
LK adapter 4Pin (12V) to 3Pin (7V)
€1.19 * €2.09 *
€1.19 *
Content 30 Zentimeter (€2.17 * / 100 Zentimeter)
€0.65 *
€5.68 *
€2.98 *
Alphacool Universal feet for radiators
€24.98 *
LK Phobya Y-Kabel 4Pin PWM auf 4x 4Pin PWM - Schwarz 60cm
Phobya Y-cable 4Pin PWM to 4x 4Pin PWM 60cm - black
Content 60 Zentimeter (€11.62 * / 100 Zentimeter)
€6.97 *
LZ Vibrationsdämpfer 120mm Lüfter Schwarz
€2.39 *
L22 Alphacool Eiszyklon Aurora LUX PRO Digital RGB (200x200x25mm)
€14.98 * €28.98 *
RAD Alphacool NexXxoS XT45 Full Copper 1260mm SuperNova Radiator
€199.98 *
ANK Alphacool HF Schnellverschlusskupplungsset 11/8mm - Black
Alphacool HF quick release connector kit 11/8mm - black
LK Phobya Y-Kabel 4Pin PWM auf 6x 4Pin PWM - Schwarz 60cm EOL
Content 60 Zentimeter (€12.47 * / 100 Zentimeter)
€7.48 *
LK Phobya 4Pin PWM Verlängerung - Schwarz 90cm
Content 90 Zentimeter (€6.20 * / 100 Zentimeter)
€5.58 *
LK Phobya Y-Kabel 4Pin PWM auf 3x 4Pin PWM - Schwarz 30cm
€4.48 *
L14 Noiseblocker NB-BlackSilentPRO PK1 ( 140x140x25mm )
€18.90 *
WZS Spritzflasche 500ml PE-LD
€4.19 *
LZ Lüftergitter für Axiallüfter für 120mm schwarz
Fan grill for axial fans for 120mm black
€1.99 *
KAB Alphacool PWM auf Mainboard PWM 40cm schwarz
Alphacool PWM to Mainboard PWM 40cm black
€4.48 *
WAC Alphacool Core 1 Silver
€99.98 *
PSU Alphacool Core 60W PSU Extern
€34.97 *
L14 Alphacool Core 140mm Lüfter PWM 2500rpm (140x140x25mm)
Alphacool Core 140mm fan PWM 2500rpm (140x140x25mm)
RAD Alphacool NexXxoS ST20 HPE Full Copper 240mm Radiator
Alphacool NexXxoS HPE-20 Full Copper 240mm Radiator
€75.98 *
WZS Alphacool ES Big Inline Partikelfilter 2x G1/4" IG
Alphacool ES Big Inline particle filter 2x G1/4" IG
€29.98 *
€44.98 *
Liefertermin: in 2 - 3 Wochen
WAK Alphacool Eisblock Aurora Acryl GPX-N RTX 3090/3080 Suprim X mit Backplate
Alphacool Eisblock Aurora Acryl GPX-N RTX 3090/3080 Suprim X with Backplate
€89.99 * €149.99 *
WZS Alphacool Core Befülltrichter
Alphacool Core filling funnel
€2.98 *
Content 3.5 Gramm (€3,708.57 * / 1000 Gramm)
Alphacool tubing AlphaTube HF 10/8 (5/16"ID) - Ultra Clear 3m (9,8ft) Retailbox
Content 300 Zentimeter (€2.66 * / 100 Zentimeter)
Leak Testing Tool incl. Pump
€34.98 *
RAD Alphacool NexXxoS XT45 Full Copper 400mm Radiator
Alphacool NexXxoS XT45 Full Copper 400mm radiator
€119.98 *
KOI Alphacool Eisbaer Aurora LT360 CPU AIO Digital RGB
€159.98 *
Alphacool Eiswasser Crystal Yellow premixed coolant 1000ml
