Alphacool Apex Stealth Metal Power fan 3000rpm matte black (120x120x25mm)
  • 13823
  • 4250197138239
  • 0,48 kg
  • 5
€21.98 * €29.98 * (26.68% Saved)
€115.98*
25667 Alphacool Core 10x 4-Pin PWM splitter with SATA power connector
€15.98*
18693 Alphacool y-splitter 3-Pin to 3x 3-Pin 30cm
€2.98*
13823 Alphacool Apex Stealth Metal Power fan 3000rpm matte black (120x120x25mm) 3x
Instead of €65.94 * (10% saved) Price for all: €59.34 *
Whisper Quiet
Powerful All-rounder
The Alphacool Apex Stealth metal fan is a true all-rounder. It sets new standards in terms of airflow and static pressure. Therefore, this fan is not only perfect for mounting on radiators, but also provides excellent airflow as a case fan. The Apex Stealth Power can be controlled between 400 to 3000 rpm via the 4-pin PWM connector. The startup speed is ~500 rpm. In addition, the Stealth offers Zero RPM control, which can be used to bring the fan to a complete stop.
Apex Design
Additional Features
Dimensions (L x W x H)120 x 120 x 25,5mm
Material (Frame)Die-cast zinc
Material (Impeller)Plastic
Weight320g
Speed400~3000±10% rpm
BearingHydro Dynamic Bearing
Connection4-Pin PWM
Start-up Voltage6 V DC
Rated Volt12 V DC
Power Consumption6.60 Watt
Rated Current0.50 A (0.55Max)
Air Flow70.98 CFM
Static Air Pressure4,23 mmH2O
Noise Level40.1 dBA
MTBF100,000h
PWM controlYes
Zero RPM controlYes
Tacho SignalYes
Auto-restartYes
Colormatte black
Warranty: 5 years
Awards & Videos
€28.98 *
€2.98 *
€2.68 *
Delivery date: in 5 - 6 weeks
€4.38 *
€3.47 *
€2.78 *
