Phobya Y-Kabel 4Pin PWM auf 3x 4Pin PWM - Schwarz 30cm
  • LK
  • 4049469100155
  • 0,019 kg
€4.48 *
Content: 30 Zentimeter (€14.93 * / 100 Zentimeter)
A Y-cable to connect 3x4-Pin PWM fans to one 4-Pin PWM connector. As fan control via the... more
As fan control via the Mainboard with a PWM fan is much more affordable than a fan controller, this cable is perfect to give more flexibility.
The extension cable is sleeved with a black mesh which additionally protects the cable and looks great! This further expands the lifespan of the cable. The ends towards the connectors are fixated with heatshrink for a clean finish.
A white marking on one of the split cables shows from which cable the rpm signal is transmitted.
Sleeving:
The idea behind these cables:
Technical specifications:
Connectors:
1x 4-Pin PWM male
3x 4-Pin PWM female
Colour: Black sleeve, black connectors, black heatshrink
Dimensions: Overall 30cm
Conforms with RoHS
Extent of delivery:
1x Phobya Y-cable 4-Pin PWM to 3x4-Pin PWM 30cm - black
This product has been reviewed for you:
Aquainfos
Tech-Review
Bauform: Y-Kabel
Hersteller: Phobya
1. Seite: 1x 4Pin PWM
Sleeving: schwarz
2. Seite: 3x 4Pin PWM
Hint!
LK adapter 4Pin (12V) to 3Pin (7V)
€1.19 * €2.09 *
Hint!
Content 30 Zentimeter (€2.17 * / 100 Zentimeter)
€0.65 *
Hint!
LK Phobya Y-Kabel 3Pin Molex auf 9x 3Pin Molex -  Schwarz 60cm EOL
Hint!
LK Phobya Adapter 3Pin (12V) auf 3Pin (7V) 20cm EOL
Content 20 Zentimeter (€17.40 * / 100 Zentimeter)
€3.48 *
WZS Spritzflasche 500ml PE-LD
€4.19 *
€11.98 *
LK Phobya Y-Kabel 4Pin PWM 2x 4Pin PWM - Schwarz 10cm
Content 10 Zentimeter (€44.80 * / 100 Zentimeter)
€4.48 *
€3.98 *
€2.98 *
PUM Alphacool Core 100 Aurora Ausgleichsbehälter Acetal/Acryl mit VPP Pumpe
Alphacool Core 100 Aurora reservoir Acetal/Acryl with Apex Pump
€84.98 * €118.98 *
Liefertermin: in 7 - 8 Wochen
L12 Alphacool Eiszyklon Aurora LUX PRO Digital RGB (120x120x25mm)
€9.98 * €12.98 *
€1.88 *
€59.98 * €79.98 *
SEN Alphacool Eiszapfen Temperatursensor flach G1/4 - schwarz
Alphacool Eiszapfen temperature sensor flat G1/4 - Black
Alphacool Eisbaer TPV Extension kit (tube and fittings)
Content 2 Stück (€7.70 * / 1 Stück)
€15.39 *
PUM Alphacool Core 200 Aurora Ausgleichsbehälter Acetal/Acryl mit VPP Pumpe
Alphacool Core 200 Aurora Reservoir Acetal/Acryl with Apex Pump
€89.98 * €124.99 *
L12 Alphacool Eiszyklon Aurora LUX PRO 2 Digital RGB (120x120x25mm)
€12.98 * €18.98 *
Alphacool Digital RGB LED y-cable 3-times with JST male connector 60cm - black
Content 60 Zentimeter (€14.97 * / 100 Zentimeter)
KAB Alphacool Y-Kabel RGB 4pol auf 3x 4pol inkl. Stecker - Schwarz 30cm
Alphacool y-cable RGB 4pol to 3x 4pol 30cm incl. connector - black
Content 30 Zentimeter (€8.27 * / 100 Zentimeter)
€2.48 * €6.49 *
Content 6 Stück (€5.50 * / 1 Stück)
€32.98 *
Hint!
LK Phobya Y-Kabel 4Pin PWM auf 6x 4Pin PWM - Schwarz 60cm EOL
Content 60 Zentimeter (€12.47 * / 100 Zentimeter)
€7.48 *
LK Phobya 4Pin PWM Verlängerung - Schwarz 90cm
Content 90 Zentimeter (€6.20 * / 100 Zentimeter)
€5.58 *
RAD Alphacool NexXxoS XT45 Full Copper 360mm Radiator
Alphacool NexXxoS XT45 Full Copper 360mm radiator
€79.98 * €98.98 *
Hint!
€0.65 *
WZS Spritzflasche 250ml PE-LD
€3.59 *
KOI Alphacool Core Ocean T38 AIO 360mm
€85.98 *
L12 Alphacool Core 120mm Lüfter PWM 3000rpm (120x120x25mm)
Alphacool Core 120mm fan PWM 3000rpm (120x120x25mm)
€8.48 *
€4.98 *
Alphacool Universal feet for radiators
Content 2 Stück (€12.49 * / 1 Stück)
€24.98 *
PUM Alphacool Eisstation DC80 - AIO Power Unit
€69.98 *
Leak Testing Tool incl. Pump
€34.98 *
