  • 18602
  • 4250197186025
  • 0,022 kg
Content: 60 Zentimeter (€13.30 * / 100 Zentimeter)
€15.98*
The new Alphacool Y-cable for 3-way digital RGB connections allows you to combine up to three... more
The new Alphacool Y-cable for 3-way digital RGB connections allows you to combine up to three individual digital RGB components from the Alphacool digital RGB family into one input. This allows you to use ARGB solutions such as ASUS AURA, MSI MYSTIC LIGHT or GIGABYTE/ AORUS ARGB FUSION to synchronize the Alphacool digital RGB products.
The cable is available in lengths of 30 cm and 60 cm.
  • 3-Pin Digital RGB Y-Adapter
  • Length 60cm
  • Connector JST
83%
Alphacool Y-cable RGBW 5-pin to 3x 5-pin incl. connector - black 30cm
Content 30 Zentimeter (€3.30 * / 100 Zentimeter)
€0.99 * €5.89 *
KAB Alphacool Eis-Matrix Verbindungskabel - 10cm EOL
Alphacool Ice Matrix connection cable - 10cm
Content 10 Zentimeter (€9.90 * / 100 Zentimeter)
€0.99 *
51%
Alphacool Eis-Matrix connection cable to 4-pin RGB - 10cm
Content 10 Zentimeter (€9.80 * / 100 Zentimeter)
€0.98 * €1.98 *
€1.48 *
KAB Alphacool Eis-Matrix II - Adapter 5-Pin auf PWM + 5V Digital RGB (3pcs) je 20cm EOL
Alphacool Eis-Matrix II - Adapter 5-Pin to PWM + 5V Digital RGB (3pcs) each 20cm
Content 20 Zentimeter (€22.35 * / 100 Zentimeter)
€4.47 *
€6.99 *
Alphacool Y-cable RGB 4-pin to 3x 4-pin incl. connector - black 60cm
€2.98 *
€28.98 *
€5.28 *
€1.98 *
€6.99 *
€1.68 *
€3.47 *
