Phobya Y-Kabel 3Pin Molex auf 9x 3Pin Molex - Schwarz 60cm
  • LK
  • 4049469078089
  • 0,043 kg
Content: 60 Zentimeter (€13.30 * / 100 Zentimeter)
For connection of 9 fans with 3-Pin connectors to a 3-Pin connector e.g. on the Mainboard.... more
For connection of 9 fans with 3-Pin connectors to a 3-Pin connector e.g. on the Mainboard. Please note that the speed monitoring of only one connected fan is possible with this adaptor cable. A white sticker on one of the cables shows which connector can be monitored.
Sleeving:
This cable is not only practical, it is also optically appealing, The surrounding mesh, also called sleeve, which is surrounding the cable itself offers the advantages that every Pro-modder is looking for: A completely unique look, even of the cables in the system! Special attention was paid to the combination of cable connectors, sleeve and heatshrink which were used to ensure great design and a unique as well as elegant look.
The idea behind these cables:
Technical specifications:
Connectors: 3-Pin to 9x 3-Pin Y-cable
Colour: Black sleeve, black connectors and black heatshrink
Dimensions: 60cm
Conforms with RoHS
Extent of delivery:
1x Phobya Y-cable 3-Pin Molex to 4x 3-Pin Molex 60cm - black
Please note: If connecting multiple fans to one fan socket by using these adapters please ensure that the source is specified to supply enough current to safely supply all fans together. Too high loads may result in damages to the system.
This product has been reviewed for you:
Aquainfos
Tech-Review
2. Seite: 9x 3Pin
Bauform: Y-Kabel
Hersteller: Phobya
Sleeving: schwarz
1. Seite: 1x 3Pin
Hint!
LK Phobya Verlängerung 3Pin - Schwarz 30cm EOL
Content 30 Zentimeter (€10.60 * / 100 Zentimeter)
€3.18 *
€5.68 *
LK Phobya Adapter 3Pin (12V) auf 3Pin (7V) - Schwarz 20cm
Content 20 Zentimeter (€17.40 * / 100 Zentimeter)
€3.48 *
Hint!
LK Phobya 4Pin PWM Verlängerung 60cm EOL
Content 60 Zentimeter (€6.63 * / 100 Zentimeter)
€3.98 *
€2.98 *
LK Phobya 4Pin PWM Verlängerung - Schwarz 90cm
Content 90 Zentimeter (€6.20 * / 100 Zentimeter)
€5.58 *
KAB Alphacool Apex PCI-e 4.0 Riser Kabel - 20cm
Alphacool Apex PCI-e 4.0 Riser cable - 20cm
Content 20 Zentimeter (€374.90 * / 100 Zentimeter)
€74.98 *
WÄM Alphacool Apex 17W/mK Thermal grease 20g
Content 20 Gramm (€2,999.00 * / 1000 Gramm)
€59.98 *
KOI Alphacool Core Ocean T38 AIO 240mm
€74.98 *
L14 Alphacool Core 140mm Lüfter PWM 2500rpm (140x140x25mm)
Alphacool Core 140mm fan PWM 2500rpm (140x140x25mm)
RAD Alphacool ES Aluminium 420 mm T38 - (For Industry only)
€47.98 *
RAD Alphacool ES Aluminium 360 mm T38  - (For Industry only)
€36.98 *
RAD Alphacool NexXxoS HPE-30 Full Copper 420mm Radiator
€121.98 *
RAD Alphacool NexXxoS XT45 Full Copper 1260mm SuperNova Radiator
€199.98 *
RAD Alphacool NexXxoS XT45 Full Copper 1080mm Nova Radiator
€149.98 *
WAK Alphacool Eisblock Aurora Acryl GPX-A Radeon 5700 XT Nitro+ EOL
€81.41 * €129.97 *
PUM Alphacool Eisball Digital RGB - Acryl (inkl. Eispumpe VPP755 V.3)
Alphacool Eisball Digital RGB - Acryl (incl. Eispumpe VPP755 V.3)
€114.98 * €129.98 *
WAC Alphacool Eisblock XPX CPU - Satin Clear Version
Alphacool Eisblock XPX CPU - satin clear version
€39.98 * €59.98 *
ANK Alphacool HF Schnellverschlusskupplungsset G1/4 - Black
Alphacool HF quick release connector kit G1/4 - black
KOI Alphacool Eissturm Hurricane Copper 45 2x140mm - Komplettset EOL
€215.39 * €249.98 *
RAD Alphacool NexXxoS ST30 Full Copper X-Flow 480mm Radiator
Alphacool NexXxoS ST30 Full Copper X-Flow 480mm radiator
€94.99 * €109.98 *
Alphacool Eiszapfen 13/10mm compression fitting G1/4 - chrome sixpack
€33.98 *
Alphacool HardTube 16/13mm Acryl clear 60cm - 4pcs
Content 240 Zentimeter (€7.91 * / 100 Zentimeter)
Alphacool HardTube 16/12mm Acryl clear 20cm
Content 20 Zentimeter (€7.45 * / 100 Zentimeter)
€1.49 * €2.59 *
PUZ Alphacool Laing DDC metal bottom - black nickel
€9.98 * €17.98 *
Liefertermin: in 8 - 9 Wochen
Alphacool tubing AlphaTube HF 13/10 (3/8"ID) - clear
Hint!
LK Phobya Verlängerung 3Pin Molex ultra lang -  Schwarz 90cm EOL
Content 90 Zentimeter (€6.09 * / 100 Zentimeter)
€5.48 *
Hint!
KAB Phobya Adapter 4Pin Molex auf 3Pin 5V/7V/12V - Schwarz 30cm EOL
€4.48 *
LK Phobya Y-Adapter 4Pin Molex auf 2x 4Pin PWM und 3Pin - Schwarz 30cm
Content 30 Zentimeter (€17.60 * / 100 Zentimeter)
€5.28 *
€23.98 *
€29.98 *
WZS Alphacool HF 38 Slotblende Panama
Alphacool HF 38 slot cover Panama
€5.68 *
Hint!
Content 30 Zentimeter (€2.17 * / 100 Zentimeter)
€0.65 *
Hint!
€3.18 *
PUM Laing DDC-Pumpe 12V DDC-1T Plus
€64.99 * €74.98 *
WZS Spritzflasche 500ml PE-LD
€4.19 *
RAB Schrauben M3 x 30mm Senk (4 Stück)
Screws M3 x 30mm flat head (4 Spcs)
€1.19 *
Schrauben M3 x 35mm Kopf (4 Stück)
€1.19 *
LK Adapter 3Pin (12V) auf 4Pin Molex (12V)
Adaptor 3Pin (12V) to 4Pin Molex (12V)
€1.79 *
