  • 17349
  • 4250197173490
  • 5,5 kg
€29.98 *
Content: 5000 Milliliter (€6.00 * / 1000 Milliliter)
Water produced specifically for Alphacool directly from a high-quality reverse osmosis system.... more
Water produced specifically for Alphacool directly from a high-quality reverse osmosis system. Purified by 5 special filters (one of which is a special reverse osmosis filter), the water is absolutely free of salts and metals, i.e. all of the components found in normal tap water. The process removes chlorine, odors, heavy metals such as lead, copper, cadmium, mercury, etc., agricultural chemicals, hormones, antibiotics, pesticides, fungicides, herbicides, drug residues, carcinogenic organic chlorine compounds, radioactive substances, asbestos fibers, tar compounds, nitrites, nitrates and other contaminants.
This means that the water does not leave any residue when it evaporates and no limescale deposits are formed. On the contrary: Due to the low pH value of 6.0 - 7.0, the Ultra Pure Water even absorbs deposits (up to a certain amount), so that the cooling system remains permanently clean.
Made in Germany
The advantages of Ultra Pure Water at a glance:
- practically non-conductive and absolutely germ-free
- no limescale deposits and no residues when evaporating
- no additives, full thermal conductivity and no interactions with other additives
- compatible with all available PC water cooling systems.
Volume5000ml
SpecificationReady-mix
UV inknot UV-active
Colortransparent
€69.98 *
€28.98 *
