Phobya Verlängerung 3Pin - Schwarz 30cm
- Article no.: LK
- EAN: 4049469077877
- Weight: 0,007 kg
Extension cable for 3-Pin cables e.g. for fans. With rpm signal lead.
Sleeving:
The idea behind these cables:
Technical specifications:
Connectors: 3-Pin extension
Black sleeve, black connectors and black heatshrink
Length: 30cm
Extent of delivery:
1x Phobya extension cable 3-Pin 30cm - black
This product has been reviewed for you:
Aquainfos
Tech-Review
2. Seite: | 1x 3Pin |
Sleeving: | schwarz |
1. Seite: | 1x 3Pin |
Hersteller: | Phobya |
Bauform: | Verlängerung |
![LK Phobya Verlängerung 3Pin - UV Blau 30cm EOL](https://aquatuning.shop-cdn.com/media/image/0c/58/d0/81030_1mQyy9ZN1UbEYH_200x200..jpg)
![LK Phobya Y-Kabel 3Pin Molex auf 9x 3Pin Molex - Schwarz 60cm EOL](https://aquatuning.shop-cdn.com/media/image/01/66/c6/81049_1ldz6clB4id7j0_200x200..jpg)
![LK Phobya Adapter 3Pin (12V) auf 3Pin (7V) 20cm EOL](https://aquatuning.shop-cdn.com/media/image/e8/c0/28/81067_1U2CudqeNwLq5u_200x200..jpg)
![LK Phobya Adapter 3Pin (12V) auf 3Pin (7V) - Schwarz 20cm](https://aquatuning.shop-cdn.com/media/image/9d/05/0d/81068_14i5DeCqUoe0yG_200x200..jpg)
![LK Phobya Verlängerung 3Pin Molex ultra lang - Schwarz 90cm EOL](https://aquatuning.shop-cdn.com/media/image/aa/f2/18/81133_1u9D7FG1paA26I_200x200..jpg)
![LK Phobya 4Pin PWM Verlängerung - Schwarz 90cm](https://aquatuning.shop-cdn.com/media/image/bb/58/d6/81134_1LL5rBsrWLnfwo_200x200..jpg)
![LK Phobya Y-Kabel 3Pin Molex auf 2x 3Pin Molex - Schwarz 30cm](https://aquatuning.shop-cdn.com/media/image/0f/4b/d5/81023_1pIX0AoVwbz2uE_200x200..jpg)
![LK Phobya Y-Kabel 3Pin Molex auf 3x 3Pin Molex - Schwarz 60cm](https://aquatuning.shop-cdn.com/media/image/1f/b5/17/81125_1z6XSE2Ken7ABX_200x200..jpg)
![LK Phobya 3er Set 3Pin Verlängerung 80cm](https://aquatuning.shop-cdn.com/media/image/09/ff/83/81113_1aafuQoV3DqIHQ_200x200..jpg)
![LK Phobya Verlängerung 3Pin Molex extra lang - Schwarz 60cm EOL](https://aquatuning.shop-cdn.com/media/image/78/1c/07/81033_1ipZON9lFQDWAz_200x200..jpg)
![WAZ Alphacool ES VE-Wasser (Reinstwasser) 5000ml](https://aquatuning.shop-cdn.com/media/image/13/3c/b7/1023014_1tMAG4GtpGURJq_200x200..jpg)
![ZK Phobya 2pin-Kabel Verlängerung Buchse/Stecker 60cm - Schwarz](https://aquatuning.shop-cdn.com/media/image/c7/f9/cf/82395_1htpdMgr639sYa_200x200..jpg)
![ZK Phobya 2pin-Kabel Verlängerung Buchse/Stecker - 30cm](https://aquatuning.shop-cdn.com/media/image/21/c0/a0/82052_12crEqGo9Eap0t_200x200..jpg)
![LK Alphacool Y-Splitter 4-Pin auf 3x 4-Pin PWM 60cm weiß](https://aquatuning.shop-cdn.com/media/image/0a/1e/67/1023496_01_200x200..jpg)
![LK Alphacool Y-Splitter 4-Pin auf 3x 4-Pin PWM 30cm weiß](https://aquatuning.shop-cdn.com/media/image/71/17/a4/1023495_01_200x200..jpg)
![WÄM Alphacool Core Wärmeleitpad Soft 6.2W/mk 100x100x3mm](https://aquatuning.shop-cdn.com/media/image/14/52/ea/1023190_12OTFy5F7BeaIn_200x200..jpg)
![WÄM Alphacool Core Wärmeleitpad Soft 6.2W/mk 100x100x2mm](https://aquatuning.shop-cdn.com/media/image/4f/b5/6e/1023189_1MezOSnbGtPKp0_200x200..jpg)
![KAB Alphacool Y-Splitter aRGB 3-Pin auf 3x 3-Pin 60cm](https://aquatuning.shop-cdn.com/media/image/de/82/fa/1023143_01MutHfHA1rB0Ju_200x200..jpg)
![KAB Alphacool Verlängerung aRGB 3-Pin auf 3-Pin 60cm](https://aquatuning.shop-cdn.com/media/image/83/28/e9/1023140_01_200x200..jpg)
![KAB Alphacool Verlängerung aRGB 3-Pin auf 3-Pin 30cm](https://aquatuning.shop-cdn.com/media/image/e9/a5/bb/1023139_01_200x200..jpg)
![KAB Alphacool Verlängerung JST aRGB 3-Pin auf 3-Pin 60cm](https://aquatuning.shop-cdn.com/media/image/cc/76/5c/1023136_01_200x200..jpg)
![KAB Alphacool Verlängerung JST aRGB 3-Pin auf 3-Pin 30cm](https://aquatuning.shop-cdn.com/media/image/b7/5d/49/1023135_01_200x200..jpg)
![LK Alphacool Y-Splitter 3-Pin auf 3x 3-Pin 30cm](https://aquatuning.shop-cdn.com/media/image/d2/82/74/1023130_01_200x200..jpg)
![LK Alphacool Y-Splitter 3-Pin auf 2x 3-Pin 15cm](https://aquatuning.shop-cdn.com/media/image/d9/19/1e/1023125_01_200x200..jpg)
![LK Alphacool Y-Splitter 4-Pin auf 4x 4-Pin PWM 30cm](https://aquatuning.shop-cdn.com/media/image/e3/3f/99/1023116_01_200x200..jpg)
![LK Alphacool Y-Splitter 4-Pin auf 2x 4-Pin PWM 60cm](https://aquatuning.shop-cdn.com/media/image/de/5a/97/1023111_01_200x200..jpg)
![LK Alphacool Y-Splitter 4-Pin auf 2x 4-Pin PWM 15cm](https://aquatuning.shop-cdn.com/media/image/9c/4e/8b/1023109_01_200x200..jpg)
