Phobya 24Pin Power Supply Extension Single Sleeving - Black 30cm
- Article no.: 87285
- EAN: 4049469100957
- Weight: 0,082 kg
- Available: Es sind weniger als 5 Artikel verfügbar
An extension for 24-pin ATX12V 2.0, EPS, WTX and ATX-GES power connector. This is usually used to extend the power supply to the mainboard, for example when the mainboard is upside down in certain cases or when using a big tower.
Sleeving "of the new generation":
With this generation, development was pushed even further and each cable was sleeved individually!
Visually, another finishing touch has been put on the case, which looks a little better in the case. The surrounding net that wraps around the actual cables is very dense and offers exactly the effect that the professional sleevers want: complete conversion of the cables to emphasize the uniqueness of their system even better! Particular attention was paid to the combination of the cable sheath (the sleeve), the connector and the shrink tubing so that they create a uniform image.
Sets:
Phobya's goal is to accommodate hobby and professional case modders a little here. Sleeving is a lot of work and takes a lot of time, so with Phobya's cables you can now rebuild your entire system the way you want, just by changing the cable.
Technical details:
Connectors: 24Pin extension
Color: black sleeve, black connector, black shrink tube
Dimensions: 30cm
RoHS compliant
1x Phobya 24Pin Power Supply Extension Single Sleeving 30cm - Black
This product was tested for you:
Aquainfos
tech review
Extremehardware ( it.)
