Phobya fan filter 120mm - black
- Article no.: LZ
- EAN: 4049469131470
- Weight: 0,059 kg
Fan filters not only keep the system clean, but are also visually appealing.
Phobya uses revised techniques to tackle a well-known problem: dust! This filter does this very well. Consisting of 3 parts, there are even more interesting refinements to discover.
The first part, the cover as the front, has a classic, unadorned look, with no visible screw heads, and protects the computer from rough parts that could be sucked in. Another protective aspect that should not be neglected: fingers and hands are protected from the fast-rotating rotor blades of the fans. The cover is removable and connected to the back via a click system.
The back is the counterpart to the cover, which forms the connection between the fan and the filter. The back also has this honeycomb pattern on the cover, which is not only aesthetically pleasing but also practical, and which firmly encloses the dust protection in its center. This is also where the mounting screws are placed, which are completely covered by the cover.
The middle part is the actual dust protection. Fine-meshed enough to keep out the smallest particles, but coarse enough not to significantly disrupt the air flow. The filter can be completely removed, making cleaning child's play.
Technical details:
Material: plastic
Color: Black
Dimensions: 121 x 121mm
Thickness: 11mm
Note for side-by-side installation:
The basic principle of this filter is that it extends a little over the 120mm fan so that it can be fully effective when mounted on the case. It therefore does not fit perfectly when mounted on radiators. In this case, a little bit would have to be removed from the edges in order to be able to mount them next to each other.
clodzenie (pl)
Größe: | 120mm |
Farbe: | schwarz |
Magnetisch: | Nein |
Hersteller: | Phobya |
Spezifikation: | Lüfterfilter |
