Alphacool Eisblock Aurora Acryl GPX-N RTX 4080 Reference Design with Backplate
- Article no.: 13441
- EAN: 4250197134415
- Weight: 1,669 kg
The next generation - the Alphacool Eisblock Aurora water cooler for Geforce RTX 4XXX graphics cards. In order to dissipate the enormous heat of this graphics card generation in the best possible way, numerous optimizations have been made to the water cooler compared to the previous model. The fin structure was adapted and enables a very good water flow while increasing the cooling surface. The modified jet plate with improved inflow engine ensures an optimal distribution of the water on the cooling fins.
Important note: The RTX 4080 Eisblock Aurora Reference cooler is not compatible with Nvidia's Geforce RTX 4080 Founders Edition.
Technical Highlights
Chrome-plated copper
Design
Thermal paste & thermal pads
- Inno3D GeForce RTX 4080 iCHILL X3, 16GB GDDR6X (C40803-166XX-187049H)
- Inno3D GeForce RTX 4080 X3 OC, 16GB GDDR6X
- Inno3D GeForce RTX 4080 X3, 16GB GDDR6X
- Inno3D GeForce RTX 4080 SUPER iCHILL Black, 16GB GDDR6X (C408SB-166XX-18700006)
- Inno3D GeForce RTX 4080 SUPER iCHILL Frostbite, 16GB GDDR6X (C408S-166XX-1870FB)
- Inno3D GeForce RTX 4080 SUPER iCHILL X3, 16GB GDDR6X (C408S3-166XX-187049H)
- Inno3D GeForce RTX 4080 SUPER X3 OC, 16GB GDDR6X (N408S3-166XX-187049N)
| Technical data cooler | |
| L x W x H | 198.41 x 144.69 x 34.40 mm |
| Pressure tested | 0.8 bar |
| Threads | 4 x G 1/4 |
| Thickness cooling fins | 0.4 mm |
| Distance cooling fins | 0.4 mm |
| Power digital aRGB LEDs | 5 V |
| Number of digital aRGB LEDs | 12 |
| L x W x H | 198.41 x 120.19 x 6 mm |
| Material | aluminium |
| Color | black |
