Phobya Adapter USB (5V) External to 3Pin Fan - Black 30cm
- Article no.: LK
- EAN: 4049469146405
- Weight: 0,012 kg
With this cable, fans can be operated easily via USB. The voltage is just right to operate a fan silently with a pleasant air flow. If you want to operate your fan outside of the case and the warm summer months are coming, fans can be converted into table fans in a flash.
Sleeving
Sets
- Length: 30cm
- Color: black
- Connectors: USB to 3 pin fan connector
Scope of delivery
- 1x Phobya Adapter USB External to 3Pin Fan 30cm – Black
2. Seite: | 1x 3Pin |
Bauform: | Adapter |
Sleeving: | schwarz |
1. Seite: | 1x 3Pin |
Hersteller: | Phobya |
Liefertermin: in 2 - 3 Tagen
