Alphacool thermal adhesive pad double-sided 120x20x0.5mm
- Article no.: 12099
- EAN: 4250197120999
- Weight: 0,005 kg
- Available: Currently there are 7 available
Alphacool's answer to the often unsolvable problem: "The cooler cannot be screwed on!"
With the double-sided thermal adhesive pad from Alphacool, you can mount your cooler in the desired location regardless of hole spacing, mounting brackets or other options provided. This is particularly interesting, for example, with the in-house MCX system for mounting mini coolers for graphics cards or motherboards. But long-term tests show that you can attach much more than just mini coolers! At least 16N / 25mm means an adhesive force that is better than some duct tape! This means that even heavier coolers can be hung up and even impacts during transport or twisting / constant pressure are no problem.
The Alphacool thermal adhesive pad also does not lose sight of the cooling performance. While the first thermal adhesive pads on the market behaved more like insulation, these pads even transfer heat at up to 1W/mK.
The pads are covered with a protective film on both sides when they are delivered. If you remove this, you can see the bright white pad, which feels almost like rubber and behaves in almost the same way. It adapts very well to the surface. Various pre-made dimensions make cutting almost unnecessary, but if it should ever be necessary to adjust the size, a pair of scissors or a knife is sufficient.
Technical data:
Material: Polymers
Color: white
Dimensions (L x W x H): 120 x 20 x 0.5 mm
Thermal conductivity: up to 1W/mk
Adhesive strength: min: 16N/25mm
electrically non-conductive
ROHS compliant
1x Alphacool thermal adhesive pad double-sided 120x20x0.5mm
Delivery date: in 10 - 11 days
Delivery date: in 6 - 7 weeks
