Alphacool Eiswolf 2 AIO - 360mm RX 7900XTX Merc 310 with Backplate
- Article no.: 14491
- EAN: 4250197144919
- Weight: 5,19 kg
Fullcover Waterblock?
Chrome-plated copper
Pump
Fittings and Tubing
Expandability
Lighting and fans
NexXxoS Radiator
Technical note!
- XFX Speedster MERC 310 Radeon RX 7900 XT Black Edition, 20GB GDDR6 (RX-79TMERCB9)
- XFX Speedster MERC 310 Radeon RX 7900 XT, 20GB GDDR6 (RX-79TMERCU9)
- XFX Mercury Radeon RX 7900 XTX Magnetic Air Gaming, 24GB GDDR6, HDMI, 2x DP, DP (RX-79XMAIRB9)
- XFX Speedster MERC 310 Radeon RX 7900 XTX Black Edition, 24GB GDDR6 (RX-79XMERCB9)
Technical data radiator | |
Material threads | Brass |
For fan size | 120 mm |
Dimensions (L x W x H) | 287,10 x 145,00 x 71,43mm |
Threads | 2 x G1/4“ |
Pump type | DC-LT 2 |
Head of delivery | 1 m |
Maximum flow rate | 72 L/h |
Voltage | 6-13.5V DC |
Power consumption | 3.2W |
MTBF | 50.000 h |
Technical data liquid | |
Color | clear |
Material | Nylon |
Color | Black |
Technical data fittings | |
Quantity 90° fittings | 2x |
Material fittings | Brass |
Technical data tube | |
Length | 50cm |
Color | Matt black |
Tube size | 12,7 / 7,6mm |
Technical data fan | |
Speed | 0 - 2500 RPM |
Air flow rate | 119,8 m³/h |
Bearings | Sleeve bearing |
Fan connector | 4-Pin PWM |
Net weight | 187g |
Vorbefüllt: | Ja |
Radiatorgröße: | 360mm |
Radiatordicke: | 29 - 39mm |
Sockel: | Nvidia GeForce |
![KOI Alphacool Eiswolf 2 AIO - 360mm RTX 3080/3090 FTW3 mit Backplate](https://aquatuning.shop-cdn.com/media/image/54/48/ee/1020892_1sck9UZESD4Jv7_200x200..jpg)
![KOI Alphacool Eiswolf 2 AIO - 360mm Radeon RX 6800/6800XT Gaming Trio X mit Backplate](https://aquatuning.shop-cdn.com/media/image/a5/5e/9e/1020900_1mLcu2WW3SaXcK_200x200..jpg)
![KOI Alphacool Eiswolf 2 AIO - 360mm Radeon RX 6800/6800XT Strix/TUF with Backplate](https://aquatuning.shop-cdn.com/media/image/70/51/49/1021887_1FO7goJvCrT2qu_200x200..jpg)
![KOI Alphacool Eiswolf 2 AIO - 360mm RTX 4080 Reference Design mit Backplate](https://aquatuning.shop-cdn.com/media/image/68/f6/48/1023273_1Hj46VqBnwiHVx_200x200..jpg)
![KAB Alphacool Verlängerung JST aRGB 3-Pin auf 3-Pin 30cm](https://aquatuning.shop-cdn.com/media/image/b7/5d/49/1023135_01_200x200..jpg)
![ROH Alphacool Eisbaer TPV Extension Set (Schlauch und Anschlüsse)](https://aquatuning.shop-cdn.com/media/image/c2/dc/f8/1019315_1k5WuKavuqDVz8_200x200..jpg)
![LK Phobya Verlängerung 3Pin - Schwarz 30cm EOL](https://aquatuning.shop-cdn.com/media/image/1e/f3/7e/81028_1TUhirHLck7yLz_200x200..jpg)
