Alphacool Eisblock Aurora Acryl RTX 4080 AMP - Trinity with Backplate
  • 13549
  • 4250197135498
  • 1,605 kg
€159.98 *
90334 Alphacool Eisplateau Anti-Static work- and mounting mat 120x60cm
€59.98*
17453 Alphacool HF compression Fitting TPV - 12,7/7,6mm Straight - Black - 6pcs Kit
€16.98*
17468 Alphacool Eiszapfen screw plug V.2 G1/4 - deep black
€3.98*
17475 Alphacool Eiszapfen PRO 13mm HardTube fitting G1/4 - deep black sixpack
€44.98*
12987 Alphacool Eisblock Aurora Terminal flat straight - Acetal
€16.98*
€12.98*
The next generation - The Alphacool Eisblock Aurora water cooler for Geforce RTX 4XXX graphics... more
The next generation - The Alphacool Eisblock Aurora water cooler for Geforce RTX 4XXX graphics cards. In order to dissipate the enormous heat of this graphics card generation in the best possible way, numerous optimizations have been made to the water cooler compared to the previous model. The fin structure was adapted and enables a very good water flow while increasing the cooling surface. The modified jet plate with improved inflow engine ensures an optimal distribution of the water on the cooling fins.
Technical Highlights
Chrome-plated copper
Design
Thermal paste & thermal pads
The included thermal compound is Alphacool's Subzero. With a thermal conductivity of 16 W/mK, it is one of the highest performing thermal pastes on the market. The electrically non-conductive thermal compund is particularly well suited for high contact pressures, but can still be processed perfectly due to its viscosity of 850000 TF. Alphacool Soft Pads with 1mm thickness are used on the voltage converter and the graphics memory. The thermal conductivity of the pads is 7 W/mK. The pads for the back of the PCB are 3mm thick and have a thermal conductivity of 3 W/mK.
- Manli GeForce RTX 4080 Gallardo, 16GB GDDR6X (N68840800M35350/N68840800M35351)
- Zotac Gaming GeForce RTX 4080 AMP Extreme AIRO, 16GB GDDR6X (ZT-D40810B-10P)
- Zotac Gaming GeForce RTX 4080 Trinity OC, 16GB GDDR6X (ZT-D40810J-10P)
- Zotac Gaming GeForce RTX 4080 Trinity, 16GB GDDR6X (ZT-D40810D-10P)
Technical data cooler
L x W x H232,30 x 145 x 34,17mm
Material cooler topacrylic
Threads4 x G1/4"
Thickness cooling fins0,4mm
Distance cooling fins0,4mm
Illuminationdigital aRGB LEDs
Power digital aRGB LEDs5V
Number of digital aRGB LEDs13
Technical data backplate
L x W x H232,30 x 120,50 x 6mm
Materialaluminium
Material Bodenplatte: Kupfer;
Hardware Hersteller: NVIDIA
Material Deckel: Acryl;
SLI kompatibel: Ja
Kühlertyp: Komplettkühler
Hinweis: Kompatibel bis 16/13mm gerade;Kompatibel bis 19/13mm gewinkelt;
Anschluss: 4x G1/4"
Hardware Modell: RTX 4080;
Abmessungen: 232,30 x 145 x 34,17mm
WAK Alphacool Eisblock GPX-N Acryl Light RTX 2080 (Super) M05 EOL
€62.63 * €99.98 *
WAK Alphacool Eisblock Aurora Acryl GPX-A Radeon 5600/5700 XT Gaming X EOL
€69.99 * €129.97 *
WAK Alphacool Eisblock Aurora Acryl GPX-A Radeon 5600/5700 XT Red Devil EOL
€74.07 * €99.98 *
WAK Alphacool Eisblock Aurora Acryl GPX-A Radeon RX 5700 XT Taichi X8 8G OC EOL
€69.99 * €99.98 *
WZS Spritzflasche 500ml PE-LD
€4.19 *
Content 15 Zentimeter (€33.20 * / 100 Zentimeter)
€4.98 *
WAK Alphacool Eisblock Aurora Acryl GPX-N RTX 3090/3080 Ventus mit Backplate EOL
Alphacool Eisblock Aurora Acryl GPX-N RTX 3090/3080 Ventus with Backplate
€89.99 * €159.97 *
PUM Alphacool Core 100 Aurora Ausgleichsbehälter Acetal/Acryl mit VPP Pumpe
Alphacool Core 100 Aurora reservoir Acetal/Acryl with Apex Pump
€84.98 * €118.98 *
Liefertermin: in 7 - 8 Wochen
RAD Alphacool NexXxoS ST25 Full Copper 360mm Radiator
Alphacool NexXxoS ST25 Full Copper 360mm radiator
€64.99 * €77.98 *
WAC Alphacool Eisblock XPX Aurora - Acryl Black Digital RGB
€54.98 * €65.99 *
AGZ Alphacool Eisbecher Acryl Tube 60x205mm
Alphacool tubing AlphaTube HF 13/10 (3/8"ID) - clear 3m (9,8ft) Retailbox
ANS 10/8mm (8x1mm) Anschraubtülle G1/4 - black nickel
€2.79 *
Liefertermin: in 2 - 3 Wochen
S16 Alphacool EPDM Tube 16/10 - Black 1m (3,28ft) Retailbox
WAC Alphacool Core 1 Aurora Silver
€119.98 *
Alphacool Core 1 Aurora Black
€119.98 *
€4.48 *
Content 60 Zentimeter (€7.47 * / 100 Zentimeter)
€4.48 *
€4.48 *
Alphacool y-splitter 3-Pin to 4x 3-Pin 30cm
Content 30 Zentimeter (€16.60 * / 100 Zentimeter)
€4.98 *
Alphacool y-splitter 3-Pin to 4x 3-Pin 15cm
€4.98 *
€4.98 *
€4.98 *
WÄM Alphacool Apex 17W/mK Thermal grease 20g
Content 20 Gramm (€2,999.00 * / 1000 Gramm)
€59.98 *
AGB Alphacool Core Distro Plate 360 Links mit VPP Pumpe
Alphacool Core Distro Plate 360 Left with VPP Apex pump
€249.98 *
KOI Alphacool Eisbaer Pro HPE Aurora 360 CPU AIO
€219.98 *
L12 Alphacool Rise Aurora 120mm Lüfter Weiß (120x120x25mm)
€15.98 * €21.98 *
WACZ Alphacool Backplate mit Schrauben LGA 115x/1200/1700
Alphacool Backplate with Screws LGA 115x/1200/1700
€6.48 *
SEN Alphacool Eiszapfen Temperatursensor flach G1/4 - chrom
Alphacool Eiszapfen temperature sensor flat G1/4 - chrom
€4.98 *
