Alphacool Eisfluegel flow indicator red 6-11mm - acrylic
  • 17357
  • 4250197173575
  • 0,019 kg
S13 Alphacool hose AlphaTube HF 13/10 (3/8"ID) - UV Red 1m (3.3ft) Retailbox 100cm
€7.98*
Alphacool Eisflügel: The flow indicator with added value! Water cooling in a computer always... more
Water cooling in a computer always serves to improve the appearance. Neatly laid hoses or hard tubes create an impressive image. The Alphacool ice wing can also be used to create a real eye-catcher. The silent rotation of the impeller always shows the direction of flow.
  • Dimensions: 88 x 40 x 15mm
  • pressure load up to 2 bar, max.
  • Connection: for hoses with an inner diameter of 6-11mm.
  • Material: ABS
Scope of delivery
  • 1x Alphacool Eisfluegel flow indicator red 6-11mm - acrylic
€3.78 *
Delivery date: in 2 - 3 weeks
€1.79 *
€3.47 *
€69.98 *
€1.89 *
€5.99 *
Delivery date: in 5 - 6 days
Delivery date: in 8 - 9 days
€27.98 *
€25.98 *
KAB Alphacool Eis-Matrix II - Adapter 5-Pin auf PWM + 5V Digital RGB (3pcs) je 20cm EOL
Alphacool Eis-Matrix II - Adapter 5-Pin to PWM + 5V Digital RGB (3pcs) each 20cm
Content 20 Zentimeter (€22.35 * / 100 Zentimeter)
€4.47 *
