Alphacool Core Geforce RTX 4080 Strix + TUF with Backplate
- Article no.: 13533
- EAN: 4250197135337
- Weight: 1,948 kg
- Asus ROG Strix GeForce RTX 4080 OC, ROG-STRIX-RTX4080-O16G-GAMING, 16GB GDDR6X (90YV0IC0-M0NA00)
- Asus ROG Strix GeForce RTX 4080, ROG-STRIX-RTX4080-16G-GAMING, 16GB GDDR6X (90YV0IC1-M0NA00)
- Asus TUF Gaming GeForce RTX 4080 OC, TUF-RTX4080-O16G-GAMING, 16GB GDDR6X (90YV0IB0-M0NA00)
- Asus TUF Gaming GeForce RTX 4080, TUF-RTX4080-16G-GAMING, 16GB GDDR6X (90YV0IB1-M0NA00)
Technical data cooler | |
Dimensions (L x W x H) | 224,03 x 158,25 x 32,03mm |
Threads | 4 x G1/4" |
Thickness cooler bottom | 11,3mm |
Illumination | digital aRGB LEDs |
Number of digital aRGB LEDs | 12 |
Color | transparent |
Technical data backplate | |
Dimensions (L x W x H) | 224,03 x 135,25 x 5mm |
Material | aluminium |
Color | black |
Anschluss: | 4x G1/4" |
Kühlertyp: | Komplettkühler |
Hinweis: | Kompatibel bis 16/13mm gerade;Kompatibel bis 19/13mm gewinkelt; |
Material Deckel: | Acryl [2] |
SLI kompatibel: | Ja |
Hardware Modell: | RTX 4080 ; |
Abmessungen: | 224,03 x 158,25 x 32,03mm |
Liefertermin: in 8 - 9 Wochen
