Alphacool Core Geforce RTX 4090 Master V.2 with backplate
- Article no.: 13837
- EAN: 4250197138376
- Weight: 2,141 kg
- Available: Currently there are 9 available
Note: This Version (V.2) of the cooler is compatible with PCB Layout V.1.1
- Gigabyte AORUS GeForce RTX 4090 Master 24G, 24GB GDDR6X (GV-N4090AORUS M-24GD)
- Gigabyte GeForce RTX 4090 Gaming OC 24G, 24GB GDDR6X (GV-N4090GAMING OC-24GD)
| Technical data cooler | |
| Dimensions (L x W x H) | 235,80 x 152,96 x 31,90mm |
| Pressure tested | 0,8 bar |
| Threads | 4 x G1/4" |
| Thickness cooler bottom | 11,3mm |
| Number of digital aRGB LEDs | 13 |
| Color | transparent |
| Dimensions (L x W x H) | 235,80 x 129,96 x 5mm |
| Material | aluminium |
| Color | black |
