Phobya 4Pin PWM Verlängerung - Schwarz 60cm
- Article no.: LK
- EAN: 4049469100094
- Weight: 0,013 kg
Extension cable for a PWM device (4-Pin).
As controlling and switching of a PWM fan via the Mainboard is much more affordable than using a fan controller, this cable is perfect for any system with PWM fans!
Black sleeve makes for a high-end and high-class finish of this cable. But the surrounding sleeve does not add to the looks of the cable, it also protects from abrasion and wear, increasing the lifespan of this cable significantly. The ends of the sleeve are covered and fixated with heatshrink tubing, creating a clean transition.
Sleeving:
This cable is not only practical, it is also optically appealing, The surrounding mesh, also called sleeve, which is surrounding the cable itself offers the advantages that every Pro-modder is looking for: A completely unique look, even of the cables in the system! Special attention was paid to the combination of cable connectors, sleeve and heatshrink which were used to ensure great design and a unique as well as elegant look.
The idea behind these cables:
Technical specifications:
Length: 60cm
Colour: Black
Connector type: 4 Pin PWM
Extent of delivery:
1x Phobya 4Pin PWM extension 60cm - black
Please note the difference between a 4-Pin power connector (Molex) and a 4-Pin fan connector (PWM).
Sleeving: | schwarz |
Hersteller: | Phobya |
1. Seite: | 1x 4Pin PWM |
2. Seite: | 1x 4Pin PWM |
Bauform: | Verlängerung |
Liefertermin: in 8 - 9 Wochen
