Phobya Y-Kabel 4Pin PWM 3x 4Pin PWM - Schwarz 10cm
  • LK
  • 4049469175580
  • 0,014 kg
€4.98 *
Content: 10 Zentimeter (€49.80 * / 100 Zentimeter)
A Y-cable to connect 3x4-Pin PWM fans to one 4-Pin PWM connector. As fan control via the... more
As fan control via the Mainboard with a PWM fan is much more affordable than a fan controller, this cable is perfect to give more flexibility.
The extension cable is sleeved with a black mesh which additionally protects the cable and looks great! This further expands the lifespan of the cable. The ends towards the connectors are fixated with heatshrink for a clean finish.
A white marking on one of the split cables shows from which cable the rpm signal is transmitted.
Sleeving:
The idea behind these cables:
Technical specifications:
Connectors:
1x 4-Pin PWM male
3x 4-Pin PWM female
Colour: Black sleeve, black connectors, black heatshrink
Dimensions: Overall 30cm
Conforms with RoHS
Extent of delivery:
1x Phobya Y-cable 4-Pin PWM to 3x4-Pin PWM 30cm - black
This product has been reviewed for you:
Aquainfos
Tech-Review
Bauform: Y-Kabel
Hersteller: Phobya
1. Seite: 1x 4Pin PWM
Sleeving: schwarz
2. Seite: 3x 4Pin PWM
Hint!
LK Phobya Verlängerung 3Pin - Schwarz 30cm EOL
Content 30 Zentimeter (€10.60 * / 100 Zentimeter)
€3.18 *
€5.68 *
Hint!
LK Phobya Y-Kabel 3Pin Molex auf 9x 3Pin Molex -  Schwarz 60cm EOL
LK Phobya Adapter 3Pin (12V) auf 3Pin (7V) - Schwarz 20cm
Content 20 Zentimeter (€17.40 * / 100 Zentimeter)
€3.48 *
L12 Alphacool Rise Aurora 120 mm Lüfter (120x120x25mm)
€11.98 * €18.98 *
WZS Spritzflasche 500ml PE-LD
€4.19 *
LK Phobya Y-Kabel 4Pin PWM 2x 4Pin PWM - Schwarz 10cm
Content 10 Zentimeter (€44.80 * / 100 Zentimeter)
€4.48 *
SEN Alphacool Eiszapfen Temperatursensor flach G1/4 - schwarz
Alphacool Eiszapfen temperature sensor flat G1/4 - Black
€2.98 *
Alphacool Eisbaer TPV Extension kit (tube and fittings)
Content 2 Stück (€7.70 * / 1 Stück)
€15.39 *
€59.98 * €79.98 *
€23.98 *
WAK Alphacool Core RX 7900XTX/XT Nitro mit Backplate
Alphacool Core RX 7900XTX/XT Nitro with Backplate
€199.98 *
Liefertermin: in 8 - 9 Wochen
€99.98 *
€4.48 *
Content 15 Zentimeter (€33.20 * / 100 Zentimeter)
€4.98 *
L14 Alphacool Core 140mm Lüfter PWM 3200rpm (140x140x25mm)
Alphacool Core 140mm fan PWM 3200rpm (140x140x25mm)
€10.98 *
L12 Alphacool Core 120mm Lüfter PWM 4000rpm (120x120x25mm)
Alphacool Core 120mm fan PWM 4000rpm (120x120x25mm)
€10.98 *
RAD Alphacool NexXxoS HPE-30 Full Copper 480mm Radiator
€122.98 *
AGB Alphacool Core 200 Aurora Ausgleichsbehälter D5/VPP Acetal/Acryl
Alphacool Core 200 Aurora reservoir D5/VPP Acetal/Acryl
€49.98 * €101.13 *
WAK Alphacool Eisblock Aurora Acryl GPX-N RTX 3080/3090 Turbo mit Backplate EOL
WAK Alphacool Eisblock Aurora Acryl GPX-N RTX 3080/3090 Turbo with Backplate
€89.99 * €159.97 *
Radiator fan mounting screw M3 x 15 mm - 4 pcs
€3.48 *
L12 Alphacool SL-15 PWM Fan 600-1800rpm ( 120x120x15mm )
€9.98 * €13.98 *
RAD Alphacool NexXxoS HPE-30 Full Copper 420mm Radiator
€121.98 *
RAD Alphacool NexXxoS HPE-30 Full Copper 360mm Radiator
€104.98 *
KOI Alphacool Eisbaer Pro Aurora 360 CPU AIO
€199.98 *
Alphacool tubing AlphaTube HF 10/8 (5/16"ID) - Ultra Clear 3m (9,8ft) Retailbox
Content 300 Zentimeter (€2.66 * / 100 Zentimeter)
Leak Testing Tool incl. Pump
€34.98 *
WAC Alphacool Eisblock XPX Aurora PRO - Acryl Black Digital RGB
€84.98 * €99.98 *
