  • 12982
  • 4250197129824
  • 0,191 kg
Content: 2 Stück (€8.49 * / 1 Stück)
€19.98*
€12.98*
€18.98*
€31.98*
€10.98*
The Alphacool Eisbaer TPV Extension Set is the easiest way to connect the expandable AIO systems... more
The Alphacool Eisbaer TPV Extension Set is the easiest way to connect the expandable AIO systems from Alphacool with other components. The extension set is compatible with all Alphacool AIO systems for processors and graphics cards. The 12.7/7.6 mm TPV hoses are each 30 cm long and have a straight Alphacool TPV nylon connection with G¼” thread at one end. At the other end there is a quick-release coupling with a male or female connection. The safety quick-release fasteners have a twist lock. This means that the quick-release fastener cannot be opened accidentally.
If you want to use the extension set to expand an Alphacool AIO solution with another product, you have to pay attention to where you use the male and female connectors. The hose with the quick-release male connector should always be mounted on the water outlet. The hose with the female quick-release connector, on the other hand, is used on the water inlet.
Download data sheet PDF: Alphacool Eisbaer TPV Extension Set
Delivery date: in 5 - 6 weeks
7%
