Alphacool Eisbaer Extreme liquid CPU cooler 280 - black edition
  • 11594
  • 4250197115940
  • 4,028 kg
  • Currently there are 9 available
€209.98 * €259.98 * (19.23% Saved)
14467 Alphacool Filling bottle Core 1000ml
€6.98*
€4.28*
13071 Alphacool Core Backplate XPX/Eisbaer LGA 115X/1200/1700/1851 Metall
€7.98*
13072 Alphacool Apex Backplate XPX/Eisbaer LGA 1700 Metall Full Cover
€15.98*
Revolutionise your system with the All in One that changes everything. The Alphacool Eisbaer... more
Revolutionise your system with the All in One that changes everything. The Alphacool Eisbaer Extreme is stronger, more beautiful and quieter than anything you've seen before in the AiO water cooling market.
Eisblock XPX- Freedom and maximum comfort
For the Eisbaer Extreme AiO, Alphacool relies on its award winning Eisblock XPX CPU cooler. It is known for its cooling performance at the highest level and impresses with its elegant design. Mounting is possible on all common AMD and Intel sockets. With the Eisbaer Extreme you enjoy absolute performance and quality.
Progress into a New Age
Alphacool gives you the flexibility you need. Use your Eisbaer Extreme perfectly thanks to the new Eisbaer Ready quick-release couplings. These are compatible with all Eiswolf / Eisbaer quick release connections. The powerful VPP Apex pump gives you the flow you need.
Individual
With the Eisbaer Extreme you decide how your system is structured. You can expand this All-in-One at any time with additional components, modify it or fill it according to your desires. Whether you install the Eisbaer Extreme horizontally or vertically, it's up to you how you showcase your water cooling system.
AMD: AM3 / AM3+ / AM4 / AM5 / FM2 / FM2+ / TR4
Intel: LGA 1150 / LGA 1151 / LGA 1155 / LGA 1156 / LGA 1200 / LGA 1366 / LGA 1700 / LGA 1851 / LGA 2011 / LGA 2011-3 / LGA 2066
Technical data (general)
Dimensions (LxWxH)385.5 x 156 x 64 mm
Housing materialaluminium
Reservoirintegrated, 138 ml
Maintenance optionsFillport with patented screw plug
Technical data Alphacool VPP Apex Pump
ControlPWM
Connection4-Pin PWM | SATA
Maximum head pressure4.25 m
Rotational speed2500-4500 rpm
Technical data Alphacool Eisblock XPX
Dimensions65 x 65 x 30 mm
Connections2x G 1/4
Pressure tested0.8 bar
Housing materialaluminium/acetal
Material bottomnickel-plated copper
Technical data Alphacool Core 140mm
Dimensions140 x 140 x 25 mm
Operating VoltageDC 7-14 V
Control Range0-2000 rpm ±10 %
Max. Air Flow103.03 CFM
Max. Static Pressure2.81 mmH₂O
Noise level38.3 (Max: 40.0) dBA
Bearing Typehydraulic Bearing
Life Expectance50 000 h at 25 °C
Connection4-Pin PWM
Speed Control Modevia PWM
KOI Alphacool Eisbaer 240 CPU - Black
Alphacool Eisbaer 240 CPU - black
€125.98 *
€27.98 *
WAC Alphacool Core 1 Silver
€6.99 *
€2.98 *
€1.48 *
Alphacool y-splitter 3-Pin to 3x 3-Pin 15cm
€2.48 *
€69.98 *
20% Cyber Monday
