Alphacool Eisbaer Aurora LT240 CPU AIO Digital RGB
  • 11678
  • 4250197116787
  • 2,559 kg
€143.98 *
ROH Alphacool Eisbaer TPV Extension Set (hose and connections)
€16.98*
15388 Alphacool Eisstation DC80 - AIO Power Unit
€73.98*
The Eisbaer LT Aurora CPU AIO water cooler offers extremely good cooling performance due to the... more
The Eisbaer LT Aurora CPU AIO water cooler offers extremely good cooling performance due to the high-end components, which includes a full copper radiator. The components used are all from Alphacool’s classic custom water cooling sector and can also be found in its enterprise products for servers. The Eisbaer LT Aurora can be expanded with additional components thanks to the quick-release fastener.
At its heart, the DC-LT 2 pump
The exceedingly small and compact DC-LT 2 pump has been further optimized compared to its predecessor. The impeller sits suspended on a ceramic axle and is supported by two magnets. A 3-phase sinusoidal drive ensures a much smoother running of the pump, which significantly contributes to minimizing noise. The pump offers enough power to add another component, such as a GPU water cooler or another radiator, to the loop. Ideally, it is coupled with an Eiswolf 2 GPU AIO water cooler. This also uses a DC-LT 2 pump.
DIY fittings and ES tubing
The tubing and fittings come from the standard custom cooling segment and all use a standard G1/4" thread. Therefore, it is extremely easy to replace them. The black TPV hose comes, like the connectors, from the Alphacool ES series which is primarily installed in servers and workstations. The hose does not contain any plasticizers and, unlike classic PVC hoses, does not deform at high temperatures. The quick connector is not made of heavy brass, but of extremely light, durable and, robust nylon. The quick connector is compatible with many other models from the Alphacool product line.
Cooler
As with all Alphacool products, the cooler base is made of nickel-plated copper and is equipped with exceptionally fine cooling fins that are distributed over almost the entire base. A flow plate provides an accelerated flow over the cooling fins which increases the cooling performance. The water flow is optimized so that all areas of the cooler base are cooled evenly.
Full Digital RGB Mounting
The pump unit and fans are fully equipped with Digital RGB LEDs, also known as Addressable RGB or aRGB. Extensive effects can be set with the included controller or with the Digital RGB controller on the motherboard. For a nice visual effect, there is an illuminated polar bear (Eisbaer). For easier control via a controller, the fans and also the pumps can be connected in series via daisy-chain. This ensures a clean wiring of the individual LED components.
AMD: AM2 / AM2+ / AM3 / AM3+ / AM4 / AM5 / FM1 / FM2 / FM2+ / SP3 / SP6 / sTRX4 / sWRX8
Technical Data Radiator
L x W x H274 x 120 x 25 mm (±3 %)
Material threadsbrass
Threads2x G 1/4
Possible fan size120 mm
Possible fan assembly2x one-sided / 4x both-sided
Technical Data cooler with pump
L x W x H69 x 69 x 45 mm
Material cooler bottomnickel plated copper
Material cooler topPMMA
Threads2x G 1/4 (+ 1x Fillport G 1/4)
Pump typeDC-LT2
Pump speed2600 rpm (±10 %)
Head of delivery1 m
Maximum flow rate72 L/h
Voltage6-13.5 V DC
Power consumption3.2 W
MTBF50.000 h
Technical data liquid
Colorclear
Ingredient 1destilled water (CAS-Nummer 7732-18-5)
Ingredient 2Glysantin (CAS-Nummer 1017-21-1)
Working temperatures15 °C/+90 °C
Technical data quick-release coupling
Dimensions95 x 27 mm
MaterialNylon
Tube size12.7/7.6 mm
Technical data connectors
Dimensions (connection straight)24 x 18 mm
Quantity (connection straight)2x
Dimensions (connection 90°)35 x 27 x 17 mm
Quantity (connection 90°)2x
Materialbrass
Technical data tube
Length40 cm
MaterialTPV (EPDM/PP)
Hardness grade35 Shore A to 50 Shore D
Maximum working temperature-50 to +155 °C
Technical data fans
Speed800-2000 rpm
Static pressure2.0 mmH₂O
Air flow rate104.49 m³/h
BearingHydraulic
Connection4-Pin PWM
Connection Digital aRGB3-Pin JST + 3-Pin 5 V
L x W x H120 x 120 x 25 mm
Cable length187 g
Voltage60 °C
KOI Alphacool Eisbaer 240 CPU - Black
Alphacool Eisbaer 240 CPU - black
€125.98 *
€33.98 *
61%
€5.78 * €14.98 *
€6.49 * €8.98 *
€1.48 *
€6.99 *
Alphacool hose AlphaTube HF 13/10 (3/8"ID) - UV Blue transparent 3m (9.8ft) Retailbox 300cm
