Alphacool ice case - measuring kit
- Article no.: 29133
- EAN: 4250197136822
- Weight: 0,377 kg
With the Alphacool measuring kit, the lengths and angles can be measured quickly and easily in order to bend HardTubes perfectly and precisely.
The set also includes rulers of different lengths, corresponding angles and a distance meter. Using the screws provided, you can screw all the rulers together and slide them along the guide slots. This means that not only one angle, but several angles and paths can be measured at the same time. Then you tighten all the screws so that nothing can slip. Now you can put the whole thing on a heat-resistant surface and heat and bend the HardTubes directly on top of it with the Alphacool Heatgun.
All parts are made of aluminum, ensuring high stability and durability.
Scope of delivery
- 1x Alphacool ice case - measuring kit
