Alphacool Ice Cyclone Aurora LUX Digital RGB - Kit of 3 (120x120x25mm)
  • 24804
  • 4250197248044
  • 0,531 kg
€25.98 * €39.25 * (33.81% Saved)
Content: 3 Stück (€8.66 * / 1 Stück)
LZ fan screws, 4 pieces (small) - silver
€0.39*
The Alphacool Eiszyklon Aurora LUX fan impresses with its aRGB LEDs and diffuse light elements,... more
The Alphacool Eiszyklon Aurora LUX fan impresses with its aRGB LEDs and diffuse light elements, which distribute the light evenly. Its strengths are particularly evident on radiators, as the fan generates a high static pressure, even when it rotates more slowly. Its maximum speed is 1100 rpm. Thanks to its naturally decoupled frame, it remains quiet and calm even at this speed. Unlike many other fans, it only has one cable, which ends in a 6-pin connector. Using the Aurora LUX Digital RGB controller from Alphacool, this one cable can be used to regulate the speed as well as set the lighting effects and colors.
Technical Data:
  • Fans
  • Size: 120 x 120 x 25 mm
  • Speed: 1100 rpm
  • Static Pressure: 2.23 mm H2O
  • Airflow rate: 87.32 m³/h
  • Bearings: Hydraulic
  • Fan/ aRGB Connector: 6-Pin
  • Illumination: Digital addressable 5V RGB LEDs
  • Controller
  • Dimensions: 93 x 47 x 17 mm (L x W x H)
  • Fan Connector: 10 x 6-pin
  • Digital RGB LED strip connector: 2x JTS 4-pin
  • Fan Voltage: 12V
  • Digital RGB LED Voltage: 5V
  • Max. Power Output: 50W
  • Control Via: Remote controller
  • Mounting: Adhesive Tape
20% Cyber Monday
€20.98 *
€1.78 *
