Phobya 3er Set 3Pin Verlängerung 80cm
- Article no.: LK
- EAN: 4049469112202
- Weight: 0,026 kg
NesteQ 3-Pin extension cables are the easiest and quickest way to expand the reach of a 3-Pin device. Simply plug this cable between device and power source for maximum flexibility. Also great to achieve a clean cable management!
Technical specifications:
Connector: 3-Pin male to 3-Pin female
Cable length: 80cm each
Colour: Black
Extent of delivery:
3x 80cm 3-Pin extension cable
Sleeving: | ohne |
2. Seite: | 1x 3Pin |
1. Seite: | 1x 3Pin |
Hersteller: | Phobya |
Bauform: | Verlängerung |
![LK Phobya Verlängerung 3Pin - Schwarz 30cm EOL](https://aquatuning.shop-cdn.com/media/image/1e/f3/7e/81028_1TUhirHLck7yLz_200x200..jpg)
![LK Phobya Verlängerung 3Pin - UV Blau 30cm EOL](https://aquatuning.shop-cdn.com/media/image/0c/58/d0/81030_1mQyy9ZN1UbEYH_200x200..jpg)
![LK Phobya Y-Kabel 3Pin Molex auf 9x 3Pin Molex - Schwarz 60cm EOL](https://aquatuning.shop-cdn.com/media/image/01/66/c6/81049_1ldz6clB4id7j0_200x200..jpg)
![LK Phobya Adapter 3Pin (12V) auf 3Pin (7V) 20cm EOL](https://aquatuning.shop-cdn.com/media/image/e8/c0/28/81067_1U2CudqeNwLq5u_200x200..jpg)
![LK Phobya 4Pin PWM Verlängerung - Schwarz 90cm](https://aquatuning.shop-cdn.com/media/image/bb/58/d6/81134_1LL5rBsrWLnfwo_200x200..jpg)
![KAB Phobya Adapter 4Pin Molex auf 3Pin 5V/7V/12V - Schwarz 10cm](https://aquatuning.shop-cdn.com/media/image/a0/25/89/87490_1SwOmrp1QGu4Na_200x200..jpg)
![LK Phobya Y-Kabel 3Pin Molex auf 2x 3Pin Molex - Schwarz 30cm](https://aquatuning.shop-cdn.com/media/image/0f/4b/d5/81023_1pIX0AoVwbz2uE_200x200..jpg)
![LK Alphacool Y-Splitter 3-Pin auf 3x 3-Pin 15cm](https://aquatuning.shop-cdn.com/media/image/d1/85/1e/1023128_01_200x200..jpg)
![WAGZ Alphacool Rise Ultra Soft Wärmeleitpad 7W/mk 50x50x3mm](https://aquatuning.shop-cdn.com/media/image/32/00/5e/1021763_1PFyMpyHDB5PBY_200x200..jpg)
![S16 Alphacool Schlauch AlphaTube HF 16/10 (3/8"ID) - Ultra Clear 1m (3,3ft) Retailbox 100cm](https://aquatuning.shop-cdn.com/media/image/8f/22/d7/1019549_1JJZc89PFAi8xA_200x200..jpg)
![KAB Alphacool Verbindungskabel 3Pin auf 3pol Digital RGB - 15cm](https://aquatuning.shop-cdn.com/media/image/d1/63/fe/1016647_1_200x200..png)
![ANS Alphacool HF 13/10 Anschraubtülle G1/4 - Deep Black Sixpack](https://aquatuning.shop-cdn.com/media/image/85/7c/4b/1012846_1Pyedsi3E7G4p1_200x200..jpg)
![S13 Alphacool Schlauch AlphaTube HF 13/10 (3/8"ID) - Klar 3m (9,8ft) Retailbox 300cm](https://aquatuning.shop-cdn.com/media/image/1c/a4/97/59306_1R5taET7SXWI1I_200x200..jpg)
![LK Phobya Y-Kabel 3Pin Molex auf 3x 3Pin Molex - Schwarz 60cm](https://aquatuning.shop-cdn.com/media/image/1f/b5/17/81125_1z6XSE2Ken7ABX_200x200..jpg)
![LK Phobya Y-Kabel 3Pin Molex auf 4x 3Pin Molex - Schwarz 60cm](https://aquatuning.shop-cdn.com/media/image/aa/03/4e/81038_1JE83vu9VepDUg_200x200..jpg)
![LK Alphacool Lüfterkabel 4-Pin auf 4-Pin Verlängerung 30cm weiß](https://aquatuning.shop-cdn.com/media/image/d0/d2/19/1023489_01_200x200..jpg)
![WÄM Alphacool Core Wärmeleitpad Soft 6.2W/mk 120x20x1mm](https://aquatuning.shop-cdn.com/media/image/93/dd/de/1023197_1l4wrZvvSOCg9H_200x200..jpg)
![WÄM Alphacool Core Wärmeleitpad Soft 6.2W/mk 40x40x0,5mm](https://aquatuning.shop-cdn.com/media/image/56/6d/c5/1023191_1sdW3bvAjFuohw_200x200..jpg)
![KAB Alphacool Verlängerung aRGB 3-Pin auf 3-Pin 30cm](https://aquatuning.shop-cdn.com/media/image/e9/a5/bb/1023139_01_200x200..jpg)
![LK Alphacool Y-Splitter 3-Pin auf 4x 3-Pin 60cm](https://aquatuning.shop-cdn.com/media/image/9e/11/3e/1023133_01_200x200..jpg)
![LK Alphacool Y-Splitter 3-Pin auf 4x 3-Pin 15cm](https://aquatuning.shop-cdn.com/media/image/7c/32/6a/1023131_01_200x200..jpg)
![LK Alphacool Y-Splitter 4-Pin auf 2x 4-Pin PWM 15cm](https://aquatuning.shop-cdn.com/media/image/9c/4e/8b/1023109_01_200x200..jpg)
![LK Alphacool Lüfterkabel 4-Pin auf 4-Pin Verlängerung 15cm](https://aquatuning.shop-cdn.com/media/image/ed/e3/59/1023106_01_200x200..jpg)
![WAGZ Alphacool Eisschicht Ultra Soft Wärmeleitpad 3W/mk 100x100x1,5mm](https://aquatuning.shop-cdn.com/media/image/80/b9/b7/1023008_15V7tjSuKcBB2v_200x200..jpg)
![ANF Alphacool Eiszapfen L-Verbinder drehbar G1/4 AG auf G1/4 IG - 4pcs Set Chrome](https://aquatuning.shop-cdn.com/media/image/dc/30/b9/1022490_17XfWL7FRwAIhi_200x200..jpg)
![ANS Alphacool Eiszapfen 16/10mm Anschraubtülle 90° drehbar G1/4 - 4pcs Set Chrome](https://aquatuning.shop-cdn.com/media/image/5d/6e/8e/1022488_1P9QoZTL1Ta4WW_200x200..jpg)
Liefertermin: in 5 - 6 Tagen
![ANS Alphacool Eiszapfen 13/10mm Anschraubtülle 90° drehbar G1/4 - 4pcs Set Deep Black](https://aquatuning.shop-cdn.com/media/image/aa/3d/46/1022485_1DYrNWrtaKb4bh_200x200..jpg)
