  • 13013
  • 4250197130134
  • 0,04 kg
€4.97 * €7.98 * (37.72% Saved)
Content: 25 cm² (€0.20 * / 1 cm²)
€62.98*
ZSO Alphacool antistatic wrist cuff blue
€4.48*
13011 Alphacool Rise Ultra Soft thermal pad 7W/mk 100x100x0,5mm
€4.88*
13014 Alphacool Rise Ultra Soft thermal pad 7W/mk 50x50x2mm
€3.97*
13020 Alphacool Apex Soft Thermal Pad 14W/mk 100x100x1mm
€44.08*
WÄM Alphacool Apex Soft thermal pad 14W/mk 2x 120x20x1mm
€25.28*
The Rise Ultra Soft are Alphacool's performance oriented solution in the range of thermal pads.... more
The Rise Ultra Soft are Alphacool's performance oriented solution in the range of thermal pads. Due to their outstanding properties, they can almost be compared to a thermal paste. The Rise Ultra Soft thermal pads nestle much better to components, which contributes to a significant improvement in cooling performance.
The material of the Rise Ultra Soft heat thermal pads acts similar to thermal paste. The consistency of the pads prevents the highest components, such as voltage converters or VRMs, from being subjected to increased contact pressure from the cooler. In extreme cases, this pressure can cause PCBs to bend. The Rise Ultra Soft Pads fill unevenness much better, nestle better against the components and thus significantly increase the heat transfer between the cooler and the component.
But that is not the only advantage!
The special material also cannot dry out. Usually, the silicone of heat-conducting pads bleeds out over time. This makes them go hard and the performance of the pads drops rapidly after a certain point. This is not the case with the Rise Ultra Soft thermal pads. They can be used for a much longer period of time without significantly losing performance.
Cutting to size? No problem!
When cutting the heat-conducting pads to size, it is essential to leave the foil on the pads. This makes it easy to cut the pads to size with scissors. This is just as easy as cutting paper. The cut edges remain perfectly clean and do not fray.
The Alphacool Rise Ultra Soft thermal pads offer better performance than standard thermal pads in many respects and are a perfect replacement for old or underperforming pads.
Dimensions (L x W x H)50 x 50 x 3mm
Specific Gravitiy ASTM D7923,3 g/cc
Thermal Conductivity ASTM D54707.0 W/mK
Hardness ASTM 224025 Shore OO
Useful Temperature-40 to +160 °C
Volume Resistivity ASTM D2575,2x1013 Ohm-m
Dielectric Constant ASTM D1504,5 MHz
Dielectric Breakdown Voltage ASTM D1495,5 kV/mm
Flame Rating UL E331100UL94 V0
Weight28 g
ColorGrey
Safety notes
Warning
  • Avoid release to the environment.
  • IF ON SKIN: Wash with plenty of water.
  • Dispose of contents/container according to local/national/international regulations.
  • Collect spillage.
  • IF IN EYES: Rinse cautiously with water for several minutes.
  • In case of fire: Do not inhale vapors.
61%
€5.78 * €14.98 *
43%
€3.97 * €6.99 *
47%
€15.78 * €29.98 *
62%
WÄM Alphacool Rise Ultra Soft Wärmeleitpad 7W/mk 100x100x0,5mm
Content 100 cm² (€0.05 * / 1 cm²)
€4.88 * €12.98 *
€6.49 * €8.98 *
31%
€23.98 * €34.97 *
50%
Alphacool Apex Soft thermal pad 11W/mk 2x 120x20x1mm
Content 48 cm² (€0.20 * / 1 cm²)
€9.58 * €18.98 *
35%
WÄM Alphacool Eisschicht Wärmeleitpad - 11W/mK 120x20x1mm - 2 Stück PHT EOL
Content 48 cm² (€0.30 * / 1 cm²)
€14.38 * €21.98 *
63%
€1.58 * €4.28 *
44%
Alphacool Core Thermal Pad Soft 9W/mk 100x100x3mm
Content 100 cm² (€0.28 * / 1 cm²)
€27.98 * €49.98 *
49%
Alphacool Core Thermal Pad Soft 9W/mk 100x100x2mm
Content 100 cm² (€0.19 * / 1 cm²)
€18.78 * €36.99 *
46%
Alphacool Core Thermal Pad Soft 9W/mk 100x100x1mm
Content 100 cm² (€0.12 * / 1 cm²)
€11.78 * €21.98 *
33%
Alphacool Core Thermal Pad Soft 6.2W/mk 120x20x1mm
Content 24 cm² (€0.20 * / 1 cm²)
€4.68 * €6.99 *
48%
Alphacool Core Thermal Pad Soft 6.2W/mk 100x100x2mm
€12.88 * €24.98 *
€1.89 *
21%
€33.97 * €42.98 *
20%
€3.97 * €4.97 *
Alphacool Eisblock Aurora mounting screws and springs M2x6mm
Content 10 Stück (€0.30 * / 1 Stück)
€2.98 *
€6.99 *
Alphacool Core double sided adhesive thermal pad 100x100x0.25mm
Content 100 cm² (€0.07 * / 1 cm²)
€6.99 *
41%
Alphacool Core Thermal Pad Soft 9W/mk 40x40x3mm
Content 16 cm² (€0.48 * / 1 cm²)
€7.68 * €12.98 *
38%
Alphacool Core Thermal Pad Soft 9W/mk 40x40x2mm
Content 16 cm² (€0.39 * / 1 cm²)
€6.18 * €9.98 *
Alphacool Core Thermal Pad Soft 6.2W/mk 120x20x1,5mm
Content 24 cm² (€0.23 * / 1 cm²)
€5.58 * €7.98 *
