Yate Loon D12SH-12 with plug (2200rpm) ( 120x120x25mm )
- Article no.: 78050
- EAN: 4049469030285
- Weight: 0,155 kg
New fan from the house of Yate Loon. Strong performance and whisper-quiet operation characterize this 120mm axial fan with bronze bearings. The fan can be connected via the 3-pin Molex connector both to a power supply (with appropriate adapters, if not available) or directly to the motherboard. The fan is also ideal for Super Silent operation at < 7V. Thanks to the extra-long connection cable of approx. 60cm, the fan can also be wired neatly in larger cases (e.g. servers or big towers) without the need for an extension cable.
Technical data:
Dimension: 120x120x25mm
Supply voltage: 12V
Speed: 2200 rpm
With 3 pin Molex connector ca 60cm cable and speed signal.
Größe: | 120mm [8] |
Abmessungen: | 120 x 120 x 25mm |
Farbe Rahmen: | schwarz |
Nennspannung: | 12V DC |
RPM Signalübertragung: | Ja |
Lüfterbundle: | 3x;4x;9x; |
LED: | nicht vorhanden [9] |
Lautstärkebereich: | 30 - 49,9 dB(A) |
Stromanschluss: | 3Pin |
Nenndrehzahl: | 2200 U/min |
Luftförderbereich: | 100 - 149 m³/h [3] |
Farbe Rotor: | schwarz |
Hersteller: | Yate Loon |
Luftförderleistung: | 149,5 m³/h |
Lautstärke: | 40 dB(A) |
