Yate Loon D90BH-12 mit Stecker (2600rpm) ( 92x92x25mm )
- Article no.: L92
- EAN: 4049469280444
- Weight: 0,085 kg
Yate Loon offers fans with particularly high static pressure and high air flow. They are particularly suitable for use as powerful case fans and offer extremely high performance even on radiators of a water cooler. Due to the classic frame, they completely cover radiators, so that all air is actually forced through the radiator. Via the 3-pin connector the fans can be easily controlled by voltage.
Technical data:
Dimensions: 92 x 92 x 16,5mm
Connection: 3-Pin
Voltage: 12V
power consumption: 2,76W
Starting voltage: 6,5V
Speed: 2600 rpm
Air flow rate: 45,9 m³/h
Static pressure: 2,1 mm/H²O
Noise emission: 34 dB(A)
Cable length: 55cm
Nennspannung: | 12V DC |
LED: | nicht vorhanden |
Stromanschluss: | 3Pin |
Luftförderbereich: | 50 - 99 m³/h |
Größe: | 92mm |
Lautstärkebereich: | 20 - 29,9 dB(A) |
Hersteller: | Yate Loon |
Abmessungen: | 92 x 92 x 15mm |
Nenndrehzahl: | 2600 U/min |
RPM Signalübertragung: | Nein |
Farbe Rahmen: | schwarz |
Farbe Rotor: | schwarz |
