Alphacool Eiszyklon Aurora LUX PRO Digital RGB (200x200x25mm)
- Article no.: 24815
- EAN: 4250197136174
- Weight: 0,194 kg
The Alphacool Eiszyklon Aurora LUX PRO 200mm fan offers a wide control range as well as outstanding digital RGB LED lighting. The individually controllable 5V aRGB LEDs paired with the special design of the fan frame create unique effects.
Ingenious Lighting
The frame is equipped with digital addressable 5V RGB LEDs which illuminate the front of the whole frame. The frame is not completely transparent, but the illumination is done through narrow slits in four places. On the upper side there are two rows of these slits. Each narrow frame runs along the inside and outside of the frame. This creates a unique illumination which looks very noble. Thanks to the recessed light diffusers the light is distributed evenly. This means that Individual LEDs are no longer visible.
Wide Control Range and Silent
The fan can be controlled from 400 to 800 rpm via the 4-pin PWM connector. At 400 rpm the fan is almost silent, but still offers a good airflow rate as well as a high static pressure. Therefore, the fan can also be used very well on radiators for a wa-ter cooling system. Thanks to the high airflow, the fan is also ideal for ventilating a case. Decouplers are also found directly on the frame. The soft foam padding reduces the transmission of vibrations to the case. A further plus point for the silent capabili-ty of the fan.
Connections?
The fan is controlled via a 4-pin PWM connector. The cable is 48 cm long. This allows the fan to be connected to the mainboard or a special controller withou t any additional adapter cables or extensions. The digital aRGB LED lighting is controlled via a JST 3-pin connector.
Technical data:
L x W x H: 200 x 200 x 27 mm
Weight: 343 g
Speed: 400 - 800rpm
Bearing: Rifle bearing
Connection fan: 4-Pin PWM
Connection Digital RGB: 3-Pin JSP + 3-Pin 5V
Cable length fan: 48 cm
Cable length Digital RGB: 48 cm
Operation voltage fan: 12V
Operation voltage Digital RGB: 5V
Power consumption: 0,14A (1,68W)
Static pressure: 1,3 - 1,52 mm H2O
Air flow: 27 - 56 m³/h
Noise: 7,4 - 23,7 dB(A)
MTBF: 50.000h
Download data sheet PDF: Alphacool Eiszyklon Aurora LUX PRO Digital RGB (200x200x25mm)
Farbe Rotor: | schwarz; |
Farbe Rahmen: | schwarz |
Nennspannung: | 12V DC |
Lebensdauer (bei 25°C): | 50.000 h |
RPM Signalübertragung: | Ja |
Luftförderbereich: | 50 - 99 m³/h [2] |
Stromanschluss: | 4Pin |
Lautstärkebereich: | 10 - 19,9 dB(A) |
Nenndrehzahlbereich: | 0 - 950 U/min |
LED: | ARGB |
Leistungsaufnahme: | 1,68W |
Größe: | 200mm [11] |
Abmessungen: | 200 x 200 x 25mm |
Nenndrehzahl: | 0 - 950 U/min |
Druck: | 1,52mm H2O |
Luftförderleistung: | 27 - 56 m³/h |
Lautstärke: | 7,4 - 23,7 dB(A) |
Liefertermin: in 10 - 11 Tagen
