Alphacool ice cyclone Aurora LUX Digital RGB (140x140x25mm)
  • 24809
  • 4250197135993
  • 0,21 kg
€5.99 * €9.98 * (39.98% Saved)
Content: 1
KAB Alphacool Eis-Matrix II - Adapter 5-Pin to PWM + 5V Digital RGB (3pcs) each 20cm EOL
€4.47*
The Alphacool Eiszyklon Aurora LUX fan offers extensive RGB lighting and is ideal as a silent... more
The Alphacool Eiszyklon Aurora LUX fan offers extensive RGB lighting and is ideal as a silent fan. With a wide control range up to a maximum of 1500 rpm, it can be operated from powerful to pleasantly quiet. The frame of the fan is of course decoupled, which further underlines its silent suitability.
Addressable digital RGB lighting
RGB was yesterday, the future lies in addressable digital RGB LEDs that can be controlled individually. Therefore, the Eiszyklon Aurora LUX fan naturally uses digital aRGB LEDs. A diffuser is used to ensure that the frame of the fan is optimally illuminated. The milky white fan frame scatters the light over the entire fan frame and ensures perfect and comprehensive illumination of the entire fan. Since each LED can be controlled individually, all known effects are possible. These include effects such as wave, pulse, breathing and much more.
Flow-optimized fan blades
The fan blades have been specially adapted for use on radiators. The most important point is a high static pressure. In order to achieve this even at low speeds, the fan blades are slightly curved. This means that they act like a shovel that draws the air inwards and presses it downwards with excess pressure. The 9 closely spaced fan blades also ensure a continuously high static pressure even at low speeds. This means that the air can be optimally pushed through a radiator. Of course, the Eiszyklon Aurora LUX fan is also suitable as a case fan.
Connections?
The fan is controlled via a 4-pin PWM connection. The cable is 44 cm long. This means that the fan can be connected to the mainboard or a special controller without any additional adapter cables or extensions. The digital aRGB LED lighting is controlled via a JST 3-pin connector.
Technical Data:
  • Dimensions: 140 x 140 x 25 mm
  • Speed: 1500 rpm
  • Static pressure: 1.93 mm H2O
  • Air flow: 118.93 m³/h
  • Bearing: Hydraulic
  • Connectors: 4-pin PWM, 3-pin JST
  • Lighting: Digitally addressable 5V RGB LEDs
  • Weight: 180g
Download data sheet PDF: Alphacool Eiszyklon Aurora LUX Digital RGB (140x140x25mm)
Rated speed range: 1000 - 1450 U/min
Air conveying area: 50 - 99 m³/h
Air flow rate: 98,54 m³/h
Pressure: 1,22mm H2O
Color Frame: Black
Rated speed: 1100 U/min
Color Rotor: Black
Nominal voltage: 12V DC
Volume: 21,0 dB(A)
RPM signal transmission: Yes
Volume range: 20 - 29,9 dB(A)
Starting voltage: 9,6V
Lebensdauer (bei 25°C): 50.000 h
Power connection: 4Pin
Dimensions: 140 x 140 x 25mm
LED: ARGB
Power consumption: 1,92W
Fan bundle: No
€1.48 *
KAB Alphacool Eis-Matrix II - Adapter 5-Pin auf PWM + 5V Digital RGB (3pcs) je 20cm
Content 20 Zentimeter (€22.35 * / 100 Zentimeter)
€4.47 *
62%
KAB Alphacool Y-Kabel RGB 4pol auf 3x 4pol inkl. Stecker - Schwarz 30cm
Alphacool Y-cable RGB 4-pin to 3x 4-pin incl. connector - black 30cm
Content 30 Zentimeter (€8.27 * / 100 Zentimeter)
€2.48 * €6.49 *
Content 6 Stück (€2.66 * / 1 Stück)
ANS Alphacool HT 16mm HardTube Anschraubtülle G1/4 - gerändelt - Deep Black Sixpack
Content 6 Stück (€4.50 * / 1 Stück)
€26.98 *
Content 240 Zentimeter (€7.91 * / 100 Zentimeter)
€1.48 *
Alphacool Y-Splitter 4-Pin to 4x 4-Pin PWM 15cm
€3.47 *
Alphacool Y-Splitter 4-Pin to 3x 4-Pin PWM 30cm
€3.47 *
Alphacool Y-Splitter 4-Pin to 3x 4-Pin PWM 15cm
€2.78 *
31%
RAD Alphacool NexXxoS HPE-45 Full Copper 420mm Radiator
€139.98 *
51%
KAB Alphacool Eis-Matrix Verbindungskabel auf 4pol RGB - 10cm
Alphacool Eis-Matrix connection cable to 4-pin RGB - 10cm
Content 10 Zentimeter (€9.80 * / 100 Zentimeter)
€0.98 * €1.98 *
34%
Alphacool Ice Cyclone Aurora LUX Digital RGB - Kit of 3 (120x120x25mm)
Content 3 Stück (€8.66 * / 1 Stück)
€25.98 * €39.25 *
Alphacool Ice Water Crystal Red Ready Mix 1000ml
76%
€1.19 * €4.89 *
54%
KAB Alphacool RGB 4pol LED Adapterkabel für Mainboards - Schwarz 50cm
Alphacool RGB 4-pin LED adapter cable for motherboards - Black 50cm
Content 50 Zentimeter (€3.96 * / 100 Zentimeter)
€1.98 * €4.28 *
Content 320 Zentimeter (€11.56 * / 100 Zentimeter)
€36.98 *
