and Conditions Alphacool Cape Corp Coolplex Pro 10 LT
  • 15718
  • 4250197157186
  • 0,31 kg
€29.98 *
The Alphacool Cape Coolplex expansion tanks have been a well-known name in the water cooling... more
The Alphacool Cape Coolplex expansion tanks have been a well-known name in the water cooling market for many years!
Even such rock-solid products need an update to meet the latest requirements. That's why we at Alphacool have discontinued our last series and are now bringing our containers made of POM with the name "LT" and the solid metal "Copper Edition" onto the market. Of course, the tubes are again made of first-class acrylic glass, which has already been used safely in your PC in the past.
The updates are very simple
In addition to the new colors, an additional threaded opening has now been added to the lid of the expansion tank. This makes filling easier with a fill port. This tank can also now be mounted flat! The riser tube, which is normally intended for venting the system, can now also be unscrewed, as it is no longer needed when the inlet comes from above. A nice side effect: We now have more space for lighting modules and can now showcase our new tank even better! To round off the whole concept even further, all the screw plugs on both models are delivered in shiny copper!
All threads are traditionally cut to a size of ¼”. Our well-known transparent holders are also included in the delivery: This makes the container a wonderful eye-catcher for your PC when illuminated by an LED!
Technical data:
  • Material: POM, acrylic
  • Height: 100mm
  • Diameter: 50mm
  • Connections: G1/4"
  • Weight: 264g
Scope of delivery
  • container
  • 2x retaining clips
  • 2 x G ¼" caps
Notice
Additional screws are required for assembly. We recommend ordering item number: 46023.
44%
Alphacool AGB Universal Mount Clip-On 50mm - Black 2 pieces
Content 2 Stück (€2.24 * / 1 Stück)
€4.48 * €7.98 *
