Adapter 3Pin (12V) auf 3Pin (9V)
- Article no.: LK
- EAN: 4260048810429
- Weight: 0,019 kg
- Verfügbar:
€0.99 *
€1.19 *
(16.81% Saved)
Content:
13 Zentimeter
(€7.62 *
/ 100 Zentimeter)
For a direct connection of a 3Pin Molex plug (CPU fan, case fan etc.) with the Mainboard. This... more
For a direct connection of a 3Pin Molex plug (CPU fan, case fan etc.) with the Mainboard. This adapter allows the operation of a fan at 9,5Volts instead of 12 Volts, therefore effectively reducing fan noise. The grat advantage of this adaptor is that the fan's speed can still be monitored directly by the Motherboard. Please note that the fan's speed is reduced with this adaptor, and therefore also the Airflow is reduced.
Technical data:
Length: 130mm
Voltage reduction: From 12V to 9,5V
Connector: Standard 3Oin Molex
Extent of delivery:
12V to 9,5V voltage adaptor 3Pin Molex
Technical data:
Length: 130mm
Extent of delivery:
Hersteller: | Aquatuning |
Sleeving: | ohne |
2. Seite: | 1x 3Pin |
Bauform: | Adapter |
1. Seite: | 1x 3Pin |
Adaptor 3Pin (12V) to 4Pin Molex (12V)
Content
22 Zentimeter
(€8.14 * / 100 Zentimeter)
€1.79
Phobya Verlängerung 3Pin - UV Blau 30cm
Content
30 Zentimeter
(€2.17 * / 100 Zentimeter)
€0.65
Phobya Y-Kabel 3Pin Molex auf 9x 3Pin Molex - Schwarz 60cm
Content
60 Zentimeter
(€13.30 * / 100 Zentimeter)
€7.98
Phobya Adapter 3Pin (12V) auf 3Pin (7V) 20cm
Content
20 Zentimeter
(€17.40 * / 100 Zentimeter)
€3.48
Content
4 Stück
(€8.50 * / 1 Stück)
€33.98
Alphacool Eisbaer TPV Extension kit (tube and fittings)
Content
2 Stück
(€7.70 * / 1 Stück)
€15.39
54%
Alphacool RGB 4pol LED adapter cable for Mainboards 50cm - black
Content
50 Zentimeter
(€3.96 * / 100 Zentimeter)
€1.98
€4.28
Alphacool y-cable RGB 4pol to 3x 4pol 60cm incl. connector - black
Content
60 Zentimeter
(€4.97 * / 100 Zentimeter)
€2.98
Phobya Y-Kabel 4Pin PWM auf 6x 4Pin PWM - Schwarz 60cm
Content
60 Zentimeter
(€12.47 * / 100 Zentimeter)
€7.48
Phobya Verlängerung 3Pin Molex ultra lang - Schwarz 90cm
Content
90 Zentimeter
(€6.09 * / 100 Zentimeter)
€5.48
Phobya Adapter 3Pin (12V) auf 3Pin (7V) - Schwarz 20cm
Content
20 Zentimeter
€3.48
Content
30 Zentimeter
€0.65
