Phobya Adapter 3Pin (12V) auf 3Pin (7V) - Schwarz 20cm
- Article no.: LK
- EAN: 4049469099855
- Weight: 0,007 kg
Adaptor for connection of a fan with 3-Pin Molex plug (CPU fan, case fan etc.) to a fan socket on e.g. the Mainboard. This adaptor allows operation of the fan with a voltage of 7V instead of 12V which allows a reduction in noise. The great advantage of this adaptor is the fact that rpm monitoring is still possible. Please consider that the speed of the connected fan will be reduced, hence resulting in a lessened airflow.
Sleeving:
The idea behind these cables:
Technical specifications:
Length: 20cm
Colour: Black
Feature: Reduces voltage from regular 12V to 7V
Connection type: 3-Pin standard
Extent of delivery:
1x Phobya adaptor 3Pin (12V) to 3Pin (7V) 20cm - Black
This product has been reviewed for you:
Tech-Review
2. Seite: | 1x 3Pin |
Bauform: | Adapter |
Sleeving: | schwarz |
1. Seite: | 1x 3Pin |
Hersteller: | Phobya |
