- Article no.: 15361
- EAN: 4250197153614
- Weight: 0,014 kg
*1The new Alphacool Twin LED RGB cable gives you unlimited possibilities for expanding your RGB setup. These LEDs can be fully controlled with the various Aurora controllers via the 4-pin RGB connector.
With a diameter of 5mm, this cable is compatible with all common 5mm LED holes in CPU coolers and expansion tanks, which opens up a wide range of possible applications.
- Length: 30cm
- LED diameter: 5mm
- Connector: 4-pin RGB
