Alphacool Eisblock Aurora RX 7900XTX Reference with backplate
- Article no.: 13547
- EAN: 4250197135474
- Weight: 1,86 kg
The next generation - the Alphacool Eisblock Aurora water cooler for Radeon RX 7XXX graphics cards. In order to dissipate the enormous heat of this graphics card generation in the best possible way, numerous optimizations have been made to the water cooler compared to the previous model. The fin structure was adapted and enables a very good water flow while increasing the cooling surface. The modified jet plate with improved inflow engine ensures an optimal distribution of the water on the cooling fins.
Technical Highlights
The fin structure of this Eisblock cooler generation was developed together with AMD board partners. The fin thickness is 0.4 mm, the distance between the cooling fins is 0.4 mm. This ensures a very good water flow while increasing the cooling surface. The jet plate has a revised inlay that spreads the water pressure better over the fins thus optimizing the heat absorption. The adjusted water inflow gives the water a better angle of inflow.
Chrome-plated copper
Design
The Aurora design of the Radeon RX 7XXX Eisblock generation is visually calmer and simpler. Only one O-ring runs around the entire cooler. The design around the cooling fins and jetplate makes for a cleaner look. The illumination of the digitally addressable RGB LEDs is even better distributed throughout the cooler as a result of the chrome plating. The terminal's design is in line with the classic Aurora design.
Thermal paste & thermal pads
- AMD Radeon RX 7900 XTX, 24GB GDDR6
- ASRock Radeon RX 7900 XTX, 24GB GDDR6
- Asus Radeon RX 7900 XTX, RX7900XTX-24G, 24GB GDDR6 (90YV0IT0-U0NM00)
- Biostar Radeon RX 7900 XTX, 24GB GDDR6 (VA7906AEF4)
- Gigabyte Radeon RX 7900 XTX 24G, 24GB GDDR6 (GV-R79XTX-24GC-B)
- PowerColor Radeon RX 7900 XTX, 24GB GDDR6 (RX 7900 XTX 24G)
- XFX Radeon RX 7900 XTX, 24GB GDDR6 (RX-79XMBABF9)
Technical data cooler | |
Dimensions (L x W x H) | 268,58 x 135,20 x 34,20mm |
Pressure tested | 0,8 bar |
Threads | 4 x G1/4" |
Illumination | digital aRGB LEDs |
Number of digital aRGB LEDs | 13 |
Color | transparent |
Technical data backplate | |
Dimensions (L x W x H) | 268,58 x 110,70 x 6mm |
Material | aluminium |
Color | black |
Cooler type: | Complete cooler |
Material base plate: | Copper |
Material Lid: | Acrylic |
SLI compatible: | Yes |
Dimensions: | 268,58 x 135,20 x 34,20mm |
Connection: | 4x G1/4" |
Hardware manufacturers: | AMD |
Hardware model: | Radeon RX 7900XTX |
