Alphacool Acrylic Tube Double Bending Tool 12-14mm and 16mm - Black
  • 29124
  • 4250197136235
  • 0,079 kg
WZS Alphacool pull saw for acrylic/PETG pipes 35cm
€17.98*
SZ Alphacool Eiskoffer - HardTube saw tool
€16.98*
Alphacool has now developed a bending tool for different sizes which makes laying and bending... more
Alphacool has now developed a bending tool for different sizes which makes laying and bending the HardTubes child's play!
HardTubes with a thickness of 12 - 14mm as well as 16mm are no problem. Curves of up to 180° can be bent easily and cleanly. With the help of the red rubber length limiters, the straight part of the tube can be adjusted in centimeter increments.
Technical data:
  • Material: Polyester
  • Color: black
  • HardTube sizes: 12 - 14mm, 16mm
  • Angle: 0° - 180°
  • Dimensions (LxWxH): 178 x 137 x 20mm
  • 1x Alphacool Acrylic Tube Double Bending Tool 12-14mm and 16mm - Black
62%
hose cutter aluminum replacement blade 3-19mm
€0.99 * €2.59 *
€28.98 *
€20.98 *
€39.98 *
€25.98 *
€37.98 *
€23.98 *
